Jester's "Texas Yeti" 1985 CJ7 Redo - Page 7 - JeepForum.com
post #91 of 393 Old 12-24-2012, 03:58 PM Thread Starter
Jester77
A shot of the other side. Yep, it's going to rub. Where's my hacksaw....sigh.
Air Force Jeep Club - Tail # 200
"You miss 100% of the shots you don't take." Wayne Gretzky
Jester77 is offline
post #92 of 393 Old 12-27-2012, 08:16 PM Thread Starter
Jester77
I managed to get some work done on the Yeti today. It was 25 degrees outside in Tejas so nothing better to do than to get the lift kit finished. Texans don't do so well in the cold, or at least this one doesn't. I started by taking my shackles over to a friend's garage where he had a ban saw. He cut right through those long bolts in no time. I had them installed right after I got home. Here's a shot of the left shackle with one of Jim Crabtree's shackle hangers finally installed.
Changing out the brake hose was no easy task. At first it felt like the two ends were welded together, but I eventually got the new on on there without too much trouble.
Installing the right leaf spring in the right rear shackle.
And a little grease on the main eye bushing...
and they slide right in with no trouble.
I need to take some time and clean up all the stickers that came on the leaf springs and do a little touch up paint and I'll be G2G.
Both rear sides are completed now. I'll pick up some shock boots tomorrow and get those installed. I will probably clean up the frame and shoot a coat of black on it to make it look somewhat descent. After I get the tires on it, I might not get it out of the garage!
I did manage to order a good bit of new brake line material this morning from Jegs. I'll install new brake lines on the rear when the new material gets in. I also managed to swing by NAPA and pick up a new fuel pump (not that I needed it but...), a new heater core, 10ft of heater hose, and the Chevy Blazer motor upgrade. I'll be tackling that project as soon as the suspension is complete. It's a never ending list....ugh....
Jester77 is offline
post #93 of 393 Old 12-27-2012, 08:17 PM Thread Starter
Jester77
Jester77 is offline
post #94 of 393 Old 12-27-2012, 08:49 PM
stamp32
For grade 5 & 8 bolts, you can try Tractor Supply. They have a decent selection.
stamp32 is offline
post #95 of 393 Old 12-27-2012, 09:19 PM
Crazyray2929
1981 CJ7
Them bushings going to the frame look like they are to small...
Did they fit real snug?
Crazyray2929 is offline
post #96 of 393 Old 12-27-2012, 09:30 PM Thread Starter
Jester77
Very snug. I had to hammer them in with a rubber mallet.
Jester77 is offline
post #97 of 393 Old 12-27-2012, 10:12 PM
Crazyray2929
1981 CJ7
Great!...
They fit snug in the spring pack also?
post #98 of 393 Old 12-28-2012, 04:24 AM Thread Starter
Jester77
Yeppers. Snug everywhere. This suspension is tight!
Jester77 is offline
post #99 of 393 Old 01-01-2013, 09:13 AM Thread Starter
Jester77
Doing the Chevy Blazer heater motor upgrade
First and foremost, I'm not trying to steal anyone's thunder or document step by step how to do this. As a matter of fact, I'm giving all the props to rixcj for posting this "how to" (http://www.jeepforum.com/forum/f8/cj...-heavy-975999/). This is the thread that I used to upgrade mine as it was very informative. It should be a sticky on doing this upgrade.
Since I already had my dash off, I decided to do this as it would be easier without all that mess in my way. I'm getting ready to order a new dash from Double D Fabrication and install new Auto Meter gauges. This is a good time for this upgrade.
I took out the computer. This thing is super dirty.
The computer was a mess and had 25+ years of oil and grime on it. Most of that junk on it is oil. I do not know where that came from. I did not see any lines or leak around this area. Weird.
I pulled the heater hoses off and drained what anti-freeze that I could. I also bought new heater hoses and a new core from NAPA. Those will be going in as well. Also, there are four bolts that hold the heater assembly to the firewall. Three are super easy to find and remove (inside the yellow circles).
The fourth one took some searching. I've been frustrated before, but not like this in a long while. The last bolt is hiding behind the valve cover on my 258. I thought I would NEVER get that last nut removed!
Once it was gone, the whole heater assembly came right out. This thing is filthy, but I've seen a lot worse. It should clean up nicely.
The heater motor is obviously caked with years of dirt and grime. I'll be glad to get the new one installed.
Some jackwagon had crimped one side of the outtake hose. It's no wonder I wasn't getting the proper amount of heat from the heater.
Jester77 is offline
post #100 of 393 Old 01-01-2013, 09:15 AM Thread Starter
Jester77
I managed to get the large metal piece sanded down and shot with a fresh coat of paint last night before calling it a day. I'm happy the way it turned out. It's definitely rust free and clean now.
I just ordered new foam from McMaster-Carr. Dunno when that will get here. I'm also documenting this as I go, so it might take a little while to post everything.
Jester77 is offline
post #101 of 393 Old 01-01-2013, 09:43 AM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
Even uncrimped, you wouldn't be getting a lot of heat from the heater, CJ heaters just aren't that good... The Blazer blower motor upgrade, or one from a YJ will give you plenty more flow, a new heater core will just give you a lot more heat transfer... all in all, good job, just do these little bits while you have it all aparts as when it is all together and you hvae to rip it apart, you thought you were frustrated with one nut? You will be learning and screaming new words when you have to "re-do" it... we have all done it, and none of us like to admit it... A few bucks now will save you a whole lot of time and screaming later.
Craig
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #102 of 393 Old 01-01-2013, 09:53 AM
CJ7Madness
Great build good luck.
CJ7Madness is offline
post #103 of 393 Old 01-01-2013, 10:08 AM
jacques25150
1982 CJ7
re
very nice job, jester;
You have given to me a lot of informations, also the others contributors (DD dash for exemple)
thank you
jacques25150 is offline
post #104 of 393 Old 01-01-2013, 11:44 PM
Skerr
Craig
X2^^^ Lots of info on the Blazer motor upgrade.
Also, were you going to Nutter your rig? I don't remember reading about it. If you do you can throw away your computer. Search Nutter.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #105 of 393 Old 01-02-2013, 05:17 AM Thread Starter
Jester77
Here's the question, if I Nutter it and remove all the junk that goes with the Nutter and I fail the emissions test, then what? Do over?
Jester77 is offline
