Jester's "Texas Yeti" 1985 CJ7 Redo - Page 20 - JeepForum.com
post #286 of 393 Old 12-01-2013, 09:08 AM Thread Starter
Jester77
Originally Posted by roboto65 View Post
I had been thinking about ya wondering where you were she's looking good.
School mostly (and some trips), but that's over with for the year. My goal is to get this finished before Christmas. I promised myself that I wouldn't watch another episode (after tonight) of The Walking Dead until it's complete.
That will motivate me!
Jester
Air Force Jeep Club - Tail # 200
"You miss 100% of the shots you don't take." Wayne Gretzky
Jester77 is offline
post #287 of 393 Old 01-25-2014, 12:42 PM Thread Starter
Jester77
LED Tail lights
Well, I finally completed the new rear wiring assembly. I built a new one (from the firewall back) that feeds the dome light, fuel sensor, brake lights, turn signals, hazard lights, reverse lights, and a good solid ground. I used some waterproof Tyco Electronics (TE) connectors, 16AWG stranded hookup wire, and Painless 1/2" power braid to tidy it all up.
A three-position TE connector. Everything was crimped, soldered, and heat shrunk where applicable.
I also ran an 8AWG OFC cable from the negative terminal on the battery to a terminal block located under the left wheel well to supply a good ground source to any accessories I hook up in the rear.
Here's a shot of the cable that runs up under the gas tank that feeds the right tail light assembly.
The left tail light with the Kentrol stainless license plate holder.
I used Rugged Ridge LED Tail Lights from Quadratec. Also, the new gas tank and fuel sender (with accoutrements) is piled in those boxes in the back.....my next project.
I also finally got around to putting the steering wheel back on.
And the DD dash looks rally nice. It looks nicer in the dark with all the instruments lit up.
And here's my little shame. He just came back from an operation and he has to wear the cone-of-shame for ten days. He's the sad dog...or at least he thinks he is.
Jester77 is offline
post #288 of 393 Old 01-25-2014, 02:38 PM
titanjeep
1980 CJ5
That looks really nice and clean. Nice work.
Air Force Jeep Club - Tail# JF183RV
2003 KJ
1980 CJ5
1988 Wagoneer
titanjeep is offline
post #289 of 393 Old 01-28-2014, 10:36 AM
roboto65
1976 CJ5
Great job love those connectors whats the link again for them. And boy he has grown lol
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #290 of 393 Old 01-30-2014, 04:44 AM Thread Starter
Jester77
No problem. They're Tyco Electronics Superseal 1.5 series connectors. Depends on how many positions you want, depends on the part number. You can buy them at Mouser or Digikey. I'm personally a bigger fan of Mouser because they are located in Mansfield, TX and I can get order the next day (since I live so close).
Yes he is. He's close to 140lbs now.
Jester77 is offline
post #291 of 393 Old 01-30-2014, 12:02 PM
REDnBLUES
1977 CJ7
[QUOTE="Jester77;19891465"]No problem. They're Tyco Electronics Superseal 1.5 series connectors. Depends on how many positions you want, depends on the part number. You can buy them at Mouser or Digikey. I'm personally a bigger fan of Mouser because they are located in Mansfield, TX and I can get order the next day (since I live so close).
Hmm. I hadn't thought of Mouser...and I drive past it every day. Are their parts decent quality?
1977 CJ7 - LT1/700R4 Project
2015 JKU Rubicon Hard Rock - stock
2013 JK Sahara - gone
REDnBLUES is offline
post #292 of 393 Old 01-30-2014, 08:31 PM Thread Starter
Jester77
They sell just about everything electronic. Top quality and very fair prices. Their selection is hard to beat.
Jester77 is offline
post #293 of 393 Old 02-01-2014, 10:00 AM
REDnBLUES
1977 CJ7
Sweet. Thanks
post #294 of 393 Old 02-03-2014, 10:03 PM
Bigmaaty
1979 CJ7
Only slightly off topic but I can't resist. Yes Mouser sells quality merchandise and they have good customer service. At least they did in the early 70's when I worked for them in high school in California. Give 'em a wave for me as you drive by.
Bigmaaty is offline
post #295 of 393 Old 02-04-2014, 08:03 PM Thread Starter
Jester77
Originally Posted by Bigmaaty View Post
...Yes Mouser sells quality merchandise and they have good customer service...
As far as I'm concerned, they still do!
Jester77 is offline
post #296 of 393 Old 02-09-2014, 02:28 PM Thread Starter
Jester77
Gas tank replacement
I am in the process of replacing the gas tank. Technically, it is the last thing I need to do to actually drive the Yeti out of the garage. My CJ came with a 20 gallon OEM tank. When I removed the old tank, I saved the old gas tank cover/skid plate as it completely encapsulated the old tank so I could reuse it with the new tank. Since you cannot get new direct replacement 20 gallon OEM tanks, I ordered a Omix-Ada 15 gallon plastic replacement tank. I had the old gas tank cover media blasted while I was waiting on Morris 4x4 to ship the new tank. Unfortunately, the new 15 gallon tank I ordered will not fit in the original gas tank cover (the tank is too tall). So I had to order a new skid plate with straps.
Here's what I ordered:
Gas Tank
Skid Plate
Driver side strap
Passenger side strap
Center strap
Fuel Sending Unit
Fuel Tank Sending Unit Brass Float
Here's a pic of the skid plate...
The gas tank...
The 5/16 brass fittings...
Both side straps installed.
Both the side straps were powder coated black and had smooth edges. However, the center strap was not powder coated and all of the edges were very sharp.
Just as a precaution, I bought a 16" bicycle inner tube...
Cut it to fit the center strap...
And everything else fit together nicely.
Of course I used a stainless steel flat washer, lock washer, and nylox nut for each bolt for good measure.
Jester77 is offline
post #297 of 393 Old 02-09-2014, 02:32 PM Thread Starter
Jester77
Gas tank replacement (cont.)
I snugged everything up...
And dry fitted the hoses.
Just waiting on the brass float for the sending unit to get here and I will install everything completely.
Jester77 is offline
post #298 of 393 Old 02-09-2014, 04:01 PM
roboto65
1976 CJ5
Always perfect looking good.
Start on mine when I get off will have parts waiting to build the engine.
roboto65 is offline
post #299 of 393 Old 02-22-2014, 09:19 PM Thread Starter
Jester77
Beautiful day here today. I started back on the fuel tank to get the sending unit mounted. You can see the area in the yellow circle where I took the Dremel and routed out a slot for the tab on the sending unit. It worked like a champ. I held the shop vac over the hole while I used the Dremel to ensure no plastic particles fell down into the tank.
The sending unit I ordered came with a plastic float. I ordered a new brass one off eBay and installed it. The little plastic shaft that came with the fuel filter that fits down in the tank broke as I was installing it. Probably a cheap Chinese part. I improvised and bent the wire mesh around the top to secure it and crimped the end to ensure the mesh would filter any larger particles that ever get inside the tank. Worked like a champ.
I inserted the sending unit...
...and it fit flush like a glove.
I put a zip tie on the feed line to remind me which fuel line to hook up. The sending unit installed nicely.
I wasn't happy with the small-size screws that held the filler neck to the filler neck housing. So I went to the hardware store and bought some stainless 10-24 allen head screws and nylox nuts. But I had to drill out the holes first.
That came together like a champ. My old filler neck housing was dry-rotted and cracked so I ordered a new one from Morris 4x4 and installed it. The part number is 5463803. That's much better than it came from the factory.
Before I install the fuel tank, I figure I will remove the differential cover and clean it up. Might as well take care of this while the tank is off. Not sure if you can see some of the orange RTV that's in some of the holes but the PO used it to make a gasket to seal the cover. What a joke. I ordered a new gasket tonight from NAPA online and I'll pick it up tomorrow.
I cleaned up the differential cover with a wire wheel and a wire brush on a drill, then gave it a bath in Dawn dish washing detergent to remove all the grease before paint.
I'm surprised that the gears weren't chewed up or missing any teeth. That would be my luck so far. I checked the lubricant that I drained for metal shavings but didn't feel any with my fingers. I'll wipe out the differential tomorrow and clean the area around the cover with a wire brush before I install the cover. I may shoot a coat of black paint on the axle housing just to clean it up a bit. More pics to follow...
Jester77 is offline
post #300 of 393 Old 02-22-2014, 10:46 PM
Kstein
I pulled my fuel sender recently...still out in fact, and it has a brass float. Thing was full of fuel. You may want to consider a secondary solder application to your new brass float. Plastic or brass: neither seem to have a good track record.
The float has been out for a couple of weeks and still seems about 3/4ths full. I wrapped in a paper towel with no sign of drainage? Not sure how to safely drain the booger.
Good Luck with your install. Have enjoyed reading about your progress.
TAMC85 CJ7
Still Original: Tub, Rollbar; Frame; 258 Block; T176; DANA300; Steering; DANA30; AMC20; Drive Shafts; Wheels; Tank; Altenator; Fan; Frt Bumper; Speedo; Heater Box; Spare Carrier; Seat risers
Replaced: Radiator; Valve Cover; Clutch linkage; Taillights; Frt Brake Calipers; Fuel, Tmp, and Oil Pressure Gauges; Exhaust line; Seat Belts; Paint
Mods: Mopar MPI(in progress); 4.0 Al Cylinder Head; OME YJ Suspension; MC Seats; Tub liner; 31" Tires
Kstein is offline
