jeeps been down for 3 months, now will not start - JeepForum.com
post #1 of 4 Old 08-15-2009, 07:44 PM Thread Starter
rjs79cj5
1979 CJ5
been working on this project for a few months now, finally reaching the end, but cann't seem to get this baby to crank. I blew out the fuel line, it's not clogged, changed the fuel pump, starter, alt., spark plugs, and wirers, it sounds as if it wants to turn over, but just won't unless you give it a shot of carb cleaner, then it will start until it burns out in a few seconds. It seems as if it isn't getting any fuel. Just not sure which way to go from here, any suggestions?
R.J.'s CJ
rjs79cj5 is offline
post #2 of 4 Old 08-15-2009, 08:38 PM
John N
1981 CJ8
If it runs on carb cleaner, you have spark. So, no fuel. Take the gas line loose at the carb, put the end of the line into a water/drink bottle and crank the engine...any fuel? If yes, then the carb is the issue. If no, then it's probably the fuel pump or the pick-up in the tank. I've also had a pinhole in a gas line that made the pump suck air instead of fuel.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 4 Old 08-15-2009, 08:50 PM
Balvar24
1979 CJ7
Float stuck?
Balvar24 is offline
post #4 of 4 Old 08-16-2009, 06:39 AM
Mackskibum
1976 CJ7
Ditto aharlow.
Take a piece of wood and a hammer and tap lightly on the side or top of the carb in a safe place (don't want to break anything). Sometimes this can knock the float loose...
'05 GMC Envoy XL SLT
'05 F250 CC XLT 4x4
'08 535XI
'76 CJ7 project
Mackskibum is offline
After months of planning/changing plans I BOUGHT A NEW ENGINE mfeldman21 Jeep CJ Forum 2 03-03-2009 11:26 AM
My ignition is being stubborn, engine doesn't start in "start" position scrible Jeep CJ Forum 6 10-04-2007 10:04 AM
First dirve after 4 months! No_Bs Jeep CJ Forum 1 05-05-2006 10:21 AM
Rock Hard Cage pics - completed a couple months ago Jeep Daddy Jeep CJ Forum 8 10-19-2004 08:44 AM
86 CJ7 Sitting For 18 months eter4 Jeep CJ Forum 5 06-02-2004 03:39 PM
