Jeep whines when going 30mph or more?? - JeepForum.com
post #1 of 8 Old 05-02-2010, 12:58 PM Thread Starter
maback
I'm not sure what's going on here. When I accelerate to more than 30, it starts to whine from the front. When I take my foot off the accelerator the noise stops. I don't think it's the front wheel bearings, they were replaced a year ago, when I converted to disk brakes, and I think they would always whine regardless of acceleration. Could this be a ujoint problem on the front driveshaft (quadratrac full time all wheel drive)? Or pinion bearing issue in the differential? The only other thing I can think of is maybe a vacuum leak.
This is whining noise and not a grinding noise. Anybody have any ideas?
maback is offline
post #2 of 8 Old 05-02-2010, 01:07 PM
80cj
80cj's Avatar
1980 CJ5
Is it doing it with the hubs unlocked?
80cj is offline
post #3 of 8 Old 05-02-2010, 01:11 PM
Lordwrench
1978 CJ7
it's a quadratrac.
Lordwrench is offline
post #4 of 8 Old 05-02-2010, 01:49 PM
80cj
80cj's Avatar
1980 CJ5
Did you check the oil level in the front differential? While you're doing that, try shaking the pinion up and down/left right. Gears would make a whining sound and could vary according to load especially drive/coast conditions. Just an educated guess.
80cj is offline
post #5 of 8 Old 05-03-2010, 04:39 AM Thread Starter
maback
I just changed the oil in the front differential, thinking that might correct the problem.. Have not tried shaking the pinion, I'll try tonight.
maback is offline
post #6 of 8 Old 05-03-2010, 10:45 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
While under there check all the fluid levels. A low oil in the trans, transfer, or even rear would whine. I know you say it is in the front, but I've heard noises transmit thru to different parts.
Rick
Cutlass327 is offline
post #7 of 8 Old 05-03-2010, 11:22 AM Thread Starter
maback
Okay, I'll check that. I regularly check and add to the transmission, because it leaks. I'll have to check the transfer case. It probably needs changing anyway.
maback is offline
post #8 of 8 Old 05-03-2010, 02:55 PM
way_of_life
1978 CJ7
definately check t-case fluid on q-trac if you have sometime rolling around under it
I don't know if that's your problem but I assume you're aware that q-track is prone to self-destruct if you don't treat it right
You mentioned u joints--U joints make a squeaking noise which is at least 2x more frequent that tire rotation, or if they're REALLY bad, they will make a clacking noise
I say check the differential and all the bearings in the area you think its coming from- don't rule out wheel bearings, and if you get in there to check them then you might as well check the spindle bearings
btw---- q-trac fluid is $10/qt on quadratec, but you can use non-detergent 30w motor oil too ( I use shell SAE30ND ) don't forget to fill the low-range unit too(if you have one and to check the morse chain while the fluid is out of it-- it will literally explode if it wears out and starts jumping
sorry if you already know all that q-trac stuff but nobody came right out and told me some of that key information so I figured I would throw it out there.
°lllllll°
way_of_life is offline
T-18 whines alot in all gears. rishar1 Jeep CJ Forum 21 03-28-2010 09:39 PM
Added 2" shackle lift, now vibrations @ 30mph+ fixable? cb_cooke Jeep CJ Forum 10 01-24-2009 08:30 AM
Dang Rearend still whines sircampsalot2 Jeep CJ Forum 6 08-08-2004 04:37 PM
