Jeep Turning Radius (Jeep Turns To The LEFT Great, Not So Much To The RIGHT) - JeepForum.com
post #1 of 9 Old 02-25-2008, 03:48 PM Thread Starter
Military Jeeper
1979 CJ5
Back when I bought my Jeep I had to take it to a shop to replace the steering box. When they installed the new steering box they never centered the steering so I have incredible turning radius to the left, but HORRIBLE turning radius to the right.
Is fixing this as simple as pulling the pitman arm and turning the wheel the opposite direction and then reinstalling?
Also, I need to center the steering wheel as well once this is done.........I have a GRANT steering wheel so I'm guessing just remove the screws and try to get center?
Jason "MJ" - 79 CJ-5 | SOA/HI-STEER | 304/T18A/D20 w/3:1 TeraLow | Holley Avenger Carb | Edelbrock Performer Intake Manifold | DUI Distributor | K&N Filter | Centerforce 2 Clutch | Waggy D44's | 4.11's | ARB's | Hydroboost | HAD Shafts | 35 Toyo MT's|
Military Jeeper is offline
post #2 of 9 Old 02-25-2008, 03:55 PM
John N
1981 CJ8
It sounds like the drag link is way out of adjustment. The pitman arm is splined and, unless you cut out the indexing splines, you'd have to turn it 90 degrees to get it back on. I'm sure you aren't off that far.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #3 of 9 Old 02-25-2008, 04:00 PM Thread Starter
Military Jeeper
1979 CJ5
Ya someone on JU suggested pulling the draglink off the pitman arm and turning all the way to left, then all the way to right, then finding the middle by how many turns there were and reinstall draglink.
post #4 of 9 Old 02-25-2008, 06:28 PM
John N
1981 CJ8
Yep...I answered some of your other questions over on JU, too.
John N
John N is offline
post #5 of 9 Old 02-25-2008, 06:58 PM
bdmonist
WTF is that?
bdmonist's Avatar
I know that's the process when installing it for the first time. So if you believe the pitman arm was not installed correctly the first time, that's what I would do. It would be easy to check. Get someone to turn all the way to each side and see how your pitarm sets at each extreme. You should be able to determine if that's your problem.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #6 of 9 Old 02-26-2008, 10:32 AM
Mike Romain
My CJ7 also does that. The steering stops aren't set even on mine. You might want to check those, they are bolts with locknuts on the back side of the hub that hit when the steering is pinned, well, that 'is' the 'pin'.
Mike
Mike Romain is offline
post #7 of 9 Old 02-26-2008, 07:34 PM
mike4089
mine does that to...i took it to an alignment shop and the dip wad said becuase it pulled to the right he adjusted the drag link so the wheel was half turned to the right in order to go straight...now that the column has been out the wheel is not even close to being straight and the turning radius sucks...im just gonna take it to nother shop and have them deal with it
mike4089 is offline
post #8 of 9 Old 02-27-2008, 09:51 AM
alpinedog
Drag link is pretty easy to adjust, do that before you spend the cash to take it in. But you will still probably need an alignment......
alpinedog is offline
post #9 of 9 Old 02-27-2008, 10:08 AM
Mike Romain
You can only align the toe in and that can be done in the driveway easily. If anything else is off, parts are worn out.
Mike
Turning radius sjecker Jeep CJ Forum 3 01-03-2009 07:40 AM
turning radius meatloaf Jeep CJ Forum 9 12-07-2008 12:21 AM
turning radius 1979CJ7 Jeep CJ Forum 13 06-18-2007 01:42 PM
turning radius limited 76 7 Jeep CJ Forum 10 05-24-2007 08:36 PM
Can you adjust the turning radius of a cj? offdapath Jeep CJ Forum 2 10-06-2005 12:27 PM
