jeep turning over but not starting (no fire) - JeepForum.com
post #1 of 5 Old 03-22-2010, 05:57 AM Thread Starter
troygolden222
We have changed the ign coil and ign module but the jeep wont fire. No power from the coil to distribitor.
troygolden222 is offline
post #2 of 5 Old 03-22-2010, 06:49 AM
Mike Romain
There is also the pickup coil in the distributor. You can test it with a multimeter. It should read 400-800 ohms between the orange and purple wires with 600 being best. Neither wire should show continuity to ground.
Next check is to be sure you have power to the coil positive when the key is in run and in start.
Mike
Mike Romain is offline
post #3 of 5 Old 03-23-2010, 07:11 AM Thread Starter
troygolden222
more information
Thanks i'm going out tomorrow and check that out. Power is getting to the coil but not the distrib. 1 hot wire getting to the distrb, no fire coming out of the coil going to the pump wire........does this make sense? This jeep sat in my garage for 7 months I just put a new battery in on Saturday and after about 5 long cranks it started. Drove out to my brother in laws Sunday to look at what was draining my battery (old issue) turns out it was a grounded wire on the horn of the new steering wheel I put on. Because the radio was loosing the presets after the jeep was cut off, we moved the radio or (*****) wire.... it was only put in pulling 6 volts instead of 12. These were the only things we did.....when I went to leave it wouldnt fire. Just wanted to explain what led up to my issue.
post #4 of 5 Old 03-23-2010, 07:20 AM
Mike Romain
I don't get the radio wiring. 6 volts?
I would undo the radio totally, maybe it is now shorting out the ignition depending on what you hooked it to.
Mike
post #5 of 5 Old 03-30-2010, 05:52 AM Thread Starter
troygolden222
Thanks!
We moved the wired and the jeep started! Weird thing is we put it back in the same spot and the jeep continues to start fine! Thanks for the help!
PLEASE help jeep won't fire 1STGENFARMBOY Jeep CJ Forum 11 12-08-2009 07:41 AM
I'm about to set my Jeep on fire! IDK Jeep CJ Forum 9 12-05-2009 09:02 PM
Jeep won't fire Jeepguy91 Jeep CJ Forum 3 01-17-2009 10:05 PM
Jeep Turning Radius (Jeep Turns To The LEFT Great, Not So Much To The RIGHT) Military Jeeper Jeep CJ Forum 8 02-27-2008 10:08 AM
Jeep died, no fire but... 143hc Jeep CJ Forum 5 05-26-2007 08:41 PM
