Jeep transmission jumping out of 2nd gear - JeepForum.com
post #1 of 10 Old 05-01-2010, 07:42 AM Thread Starter
Tigerpaw
1983 CJ8
I have a late model 70's cj7-- 3-speed jumping out of second gear but if the shift is held it will stay in gear. All bolts are tight on everything. What needs to be done and any idea on cost. Everything else shifts fine.
Tigerpaw is offline
post #2 of 10 Old 05-01-2010, 08:06 AM
AlbuqHenry86cj7
My guess it trans is tired. needs rebuild which would be all new bearings and a new 2nd gear. The BW t90 is famous for this... not sure what trans you have but on the t-90 the kit was about $150..
Parts for the T90 Transmission
AlbuqHenry86cj7 is offline
post #3 of 10 Old 05-01-2010, 09:27 AM
Eaallred
My T90 was doing this as well. Fresh rebuild too. Normally caused by the integral bushing in 2nd gear wearing out, but mine was brand new and still popped out on a downshift.
I ended up putting the shift tower in my vice and putting a large crecent wrench on the shift fork and 'tweaking' it little by little to push it into second gear further and now it works flawlessly. Just do a little at a time until it works right. It doesn't take a lot of bending, just a tweak is all.
Eaallred is offline
post #4 of 10 Old 05-01-2010, 09:28 AM
curbcrawler
1946 CJ2A
Im guessing a wore syncro.
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. - Benjamin Franklin
-commit2013-
curbcrawler is offline
post #5 of 10 Old 05-01-2010, 09:33 AM Thread Starter
Tigerpaw
1983 CJ8
Found the tranny number its a T150 married to a Dana 20. No shifter binding pulled the plates and still jumps out.
Tigerpaw is offline
post #6 of 10 Old 05-01-2010, 09:33 AM
79cj7stone
1979 CJ7
Haha mines does this too but only if you get on it a little. So it has become a habit just to hold it in there. Haha
79cj7stone is offline
post #7 of 10 Old 05-01-2010, 07:28 PM
4lowherewego
1979 CJ7
mine does too....i dont let go of shifter often tho only 2 take a drink I have T14 to Dana20 in 72CJ5
4lowherewego is offline
post #8 of 10 Old 05-01-2010, 07:50 PM
243
1978 FSJ Cherokee
I am not sure if the T-150 and T-176 have similar shifter covers but if they do, the shift rods have grooves in them with a ball bearing and spring in the shift cover. When you shift into a gear, the poppet spring pushes the ball into the groove and holds it into place.
I don't think I have a picture of my shift cover disassembled but I will post a picture of the inside for comparison.
It would be worth a try to rebuild (disassemble and clean) the shift cover.
Dave's 78 Build
243 is offline
post #9 of 10 Old 05-01-2010, 08:07 PM
jumbojeepman
1976 CJ7
One thing that can lead to this problem is leaving your hand on the shifter in between shifts. You should completely remove your hand from the shifter and your foot from the clutch in between every shift.
jumbojeepman is offline
post #10 of 10 Old 05-01-2010, 09:01 PM
243
1978 FSJ Cherokee
Maybe this will help, the T-4 and T-5 appear to have similar top covers after looking at the FSM.
Cover with the shift rod retainers in place.
Retainer plates removed.
One shift rod removed and you can see the poppet ball. A couple of the springs in my cover were broken into several pieces.
Dave's 78 Build
243 is offline
Jumping Out Of First Gear Oily Jeep CJ Forum 6 03-07-2011 03:53 PM
3 speed jumping out and not staying in gear droopycj5 Jeep CJ Forum 3 02-15-2009 11:22 AM
My CJ7 seems to be jumping in 3rd gear and can't figure it out... DaculaJeep Jeep CJ Forum 10 01-24-2009 08:14 PM
jumping out of 1st gear BigTroy Jeep CJ Forum 3 01-05-2009 11:04 PM
Awesome Jeep Transmission, gear ratio, tire size, rpm calculator hfjeff Jeep CJ Forum 1 06-17-2006 08:00 PM
