Jeep starting issues - JeepForum.com
post #1 of 11 Old 01-07-2012, 08:12 PM Thread Starter
teenfalcon13
Drove my 81' CJ7 around all day today with no issues. Then just a couple hours ago went out to crank it up and its trying to turn over but won't. Seems like it could be a fuel filter, or fuel pump issue. Just changed all of the spark plugs, spark plug wires and new cap and rotor. Seems weird that it's an issue as it has never been before. Even when I try and give it gas it doesn't seem like its getting it.
teenfalcon13 is offline
post #2 of 11 Old 01-07-2012, 08:12 PM Thread Starter
teenfalcon13
Correction though it's irrelevant to the issue at hand, it's a 85' lol
post #3 of 11 Old 01-07-2012, 08:16 PM
mopar346
Fill out your profile and people will know the specifics on your CJ. Does it spin at the proper speed or does it seem slower? Do you know how to prime the carburetor? Does it sputter or anything? How you checked for spark?
These answsers will help with recommendations of what to look for.
Careful your character's showing
mopar346 is offline
post #4 of 11 Old 01-08-2012, 07:37 AM Thread Starter
teenfalcon13
I updated it a little more. I am not totally certain of some of the specifics that it asks me for. As far as the jeep is concerned it does seem to be spinning at the proper speed. I do know how to prime the carb, and there is no sputtering. It is trying to turn over just wont, as vague as that sounds. Also there is spark I had a buddy check and it shocked him pretty good! lol I may post a video link and upload a video to youtube.
post #5 of 11 Old 01-08-2012, 08:13 AM
mopar346
OK, 9sounds fuel delivery then, have you tried it this morning? It could be a vapor lock.
Priming the carb is simply putting a little fuel directly in the throat of the carb, it must be done carefully since you are dealing with raw fuel it can be dangerous. You only put a small amount in, several table spoons and then put the fuel source far away and crank the engine, if it fires up you then you have confirmed a fuel supply issues.
mopar346 is offline
post #6 of 11 Old 01-08-2012, 08:17 AM
lucdog
lucdog's Avatar
1980 CJ5
Does the fuel gauge work, and your 100% sure there is gas in the tank.
It runs when you pour a little gas in the carb for 2or 3 seconds?
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #7 of 11 Old 01-08-2012, 08:29 AM
CJ Chet
You might check your fuel filter. Make sure the return is at 12 o'clock position in relation to the output port (center).
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #8 of 11 Old 01-08-2012, 09:53 AM
carnell
Another thing to look for is the 15amp (Blue) fuse. If thats blown, it cuts power to your module. I found this out the hard way..... Troubleshot for a week then took it to the stealership and they found it. Couldn't find a reason why it blew, but now I keep a a bunch of spares with me now.
carnell is offline
post #9 of 11 Old 01-08-2012, 07:55 PM Thread Starter
teenfalcon13
Well as you all know it started with that. Checked the fuel by cranking it while the line was off the carb. Definitely good with the pump. Filter was also good. After running those checks I then tried starter fluid in the carb and still no start. So after a few more attempts the whole ignition seemed to go out. I turn the key and there was absolutely no response. This is already making me mad. Luckily I have AAA and I took it to a shop. I will let everyone know what the problem(s) are. Thanks for the advice.
post #10 of 11 Old 01-08-2012, 10:25 PM
carnell
So you checked the fuse????
carnell is offline
post #11 of 11 Old 01-09-2012, 07:06 AM Thread Starter
teenfalcon13
Yeah I checked all fuses and all were in tact. This same thing happened to my CJ5, and it ended up being my ignition switch in my steering column.
