Jeep Stalls Out - JeepForum.com
post #1 of 5 Old 03-18-2002, 04:32 PM Thread Starter
Jami
1973 CJ6
Post Jeep Stalls Out
I need help. I have a 1980 CJ7 with a 304. The 304 has holley projection, a crower cam, edelbrock intake and assorted other bolt ons. My problem is that it idles fine but as soon as you start to drive it stalls out. You can drive it in four low but none of the others. I checked the plugs, timing and vacum advance, replaced the plug wires, cap, and rotor as well as the fuel filter. If anyone has any suggestions I would greatly appreciate it.
Thanks Jami
73 CJ-6 in the works
Jami is offline
post #2 of 5 Old 03-19-2002, 07:53 PM
Bulletproofcj7
Post
Hey Jami, It sounds like the engine needs to be running at a higher rpm if it only runs in low range.
maybe a fuel pump problem?
I'm not familiar with those F.I. systems does it have an electric fuel pump? is it putting out enough pressure? They usually require a certain amount of pressure to work properly. or do you have a stock pump that may be bad? maybe holley has a tech support line you can call.
I am curios about that fuel injection though, how do you like it? have you had a chance to use it or did you just install the system? good luck!
jason
I think i have read that it is sopposed to be used with the stock manifold.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #3 of 5 Old 03-19-2002, 07:56 PM
Bulletproofcj7
Post
It does'nt have a points distributer does it?
post #4 of 5 Old 03-20-2002, 05:11 AM Thread Starter
Jami
1973 CJ6
Post
The system does have an electric fuel pump, but I have not gotten around to check the pressure. That will probably be my next step to check it in both lines(it has a return). I haven't had the system on long but it was used(it was used on this engine). It ran great and I like it's flexibility of adjustment. I will keep you posted.
Jami is offline
post #5 of 5 Old 03-20-2002, 05:13 AM Thread Starter
Jami
1973 CJ6
Post
Sorry,
No it does not have a points distributor, it has a Mallory magnetic breakerless distributor and pro master coil..
Jami is offline
258 just up and stalls mmerlina Jeep CJ Forum 4 11-22-2009 06:21 AM
258 stalls at 20 mph 80HouLaredo Jeep CJ Forum 3 11-08-2009 01:02 PM
jeep stalls when brakes applied Sedorbrian Jeep CJ Forum 14 05-09-2009 06:48 AM
258 stalls when w/o AC on thundermunkey Jeep CJ Forum 3 01-06-2009 11:47 AM
304 stalls when hot. 79' cj-7 mudmud Jeep CJ Forum 2 03-11-2003 08:44 AM
