Jeep running rough as hell -replaced carb still running the same. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jeep running rough as hell -replaced carb still running the same.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE Shipping Sale!FS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-25-2015, 08:54 PM   #1
agear
Cj Jeep running rough as hell -replaced carb still running the same.
My jeep started sputtering one day on the way home from work . Before hand it had been running fine. I had the weber 32/36 or whatever. I got my brother in law to adjust the carburetor and I replaced both of my fuel filters - it ran better for a few then started running like crap again. My brother in law thought it might be trash in the carburetor. So this was a great excuse to upgrade to the 390 cfm 38 weber carburetor. I put it on and its still running the same way. With the jeep running I wiggled my alternator wires and my coil wires but that didn't make it how it was running change. I also looked at my module from under the jeep and didn't see anything melted and kind of dripping down. I looked at the lines and hoses at my gas tank and I don't see or smell any gas leaking. Could it be the fuel pump ?
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline   Reply With Quote Quick reply to this message
Unread 07-26-2015, 05:30 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Dirty distributor cap and rotor?
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 07-26-2015, 06:47 AM   #3
Cashcrazy
1983 CJ7
Did you check spark plugs?
1982 CJ7(sold), 1983 CJ7(sold), 1989 YJ(sold), 1983 CJ7 undergoing frame-off.
Cashcrazy is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 02:32 PM   #4
agear
I looked at the spark plugs a month ago when I did my head gasket -they all had a tan spot on there except one which had a black spot. Haven't looked at the cap and rotor yet but I'm sending the carburetor back for a replacement because the secondary throttle was binding a little but I don't believe that was my issue because it ran the same with new carburetor as it did with the old
Unread Yesterday, 02:59 PM   #5
Skerr
Intake leak? Sure will make it run poorly.
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:15 PM   #6
Colubrid
1979 CJ7
agear, Post if you get this fixed, my 79 started doing the same recently. The stock carb was removed and "cleaned" twice, ran good for two days then messed up again. I'm wondering if bad gas or crap in the gas tank might cause this... This is my first post by the way, glad to be here.
Colubrid is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:28 PM   #7
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
agear,
I think we need a little more info. "Running rough as hell..." doesn't quite do it.
What are the symptoms? Does it run OK warm or cold? Or is rough all the time?
You mentioned one black spark plug. Have you confirmed spark in that cylinder?
Matt
Matt1981CJ7 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 11:13 PM   #8
ikidd
So you replaced the fuel filters and it ran better for a while, then went to hell again? Are you able to cut open the old ones and see if they were plugged? Maybe the new ones are as well now, and that will tell you something.
1998 ZJ 5.9 - 4", NP242
1998 ZJ 4.0 - Stock
1977 CJ7 304 Auto
1994 ZJ 4.0 "Rammy" RIP
ikidd is offline   Reply With Quote Quick reply to this message
