Jeep is not level - Page 2 - JeepForum.com
 1Likes
post #16 of 24 Old 02-09-2017, 07:08 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Yes.
Matt
Matt1981CJ7 is offline
post #17 of 24 Old 02-09-2017, 08:27 PM
justals
I had a similar incident with my cj...jeep had 33s on all corners. Needed to replace the front right so brought to tire store. Picked up and drove home. Noticed lean, check tire size and they put a 35 on. Looked good but didn't want to spend the $$ for the 3 others. Put correct tire on and lean fixed..
85 CJ - Renegade; 85 CJ - Base; 86 CJ - Laredo
14 JKU - Rubicon; 14 Cherokee - Latitude
justals is offline
post #18 of 24 Old 02-10-2017, 01:28 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Add some helper air bags and level it out as needed.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #19 of 24 Old 02-10-2017, 04:47 AM
mopar440cu
A.H.B.A. Memember
mopar440cu's Avatar
1979 CJ5
Just put a spacer plate between the spring and spring perch. For example, If you are looking at it from the front and the Jeep is leaning on the left the spacer needs to go in the right rear to help level out the front. There is a lot of articles on this subject. Its an easy fix, you just need to know the measurements for the spacer then fab one up.
1979 CJ5- SOA, 304, T18,D20, D30,Model 20 with trac loc/moser axles both 4:56 geared and 35 TSL swampers.
1978 CJ5-SOA,9:1 360, T18A,D20, D30 and M20 w/4:56.
1979 CJ5 SOA 360, T-18/D20, 4:88 gears,36 Swampers
mopar440cu is offline
post #20 of 24 Old 02-10-2017, 08:15 AM Thread Starter
ggking7
1960 CJ6
I'll switch the front left and right springs tomorrow and report back. Any tricks to it?
ggking7 is offline
post #21 of 24 Old 02-10-2017, 08:33 AM
JoonHoss
2011 JK Wrangler
Except that he already reported a difference between frame/ spring measurements, which means his springs are off (to start with)
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #22 of 24 Old 02-10-2017, 08:53 AM
Matt1981CJ7
1981 CJ7
1. Use your 2 jack stands to support the frame, just behind the fixed spring hangers, with the front wheels in the air.
2. Remove the front wheels, so the axle is easier to handle.
3. Use the jack to support the axle, while you remove the springs. It helps to jack the axle up to the "neutral" position to take any loading off the springs.
4. Remove the u-bolts, first, then the rear fixed hanger bolts. Let the rear of the springs down to the ground, then disconnect the front shackles from the springs. Try to keep the axle stationary while you do this. Additional blocks or straps may be necessary to keep the axle from rotating off the jack.
5. Re-assemble in the reverse order
Although many of us have done this solo, I encourage you to recruit some help. An extra set of hands will make it go a lot easier.
Good luck,
Matt
post #23 of 24 Old 02-17-2017, 06:03 AM
mopar440cu
A.H.B.A. Memember
mopar440cu's Avatar
1979 CJ5
Hoss
Hoss,
I had the same problem with one of my CJ5's and the only thing that solved it was to put a shim in the rear. I had to take the lessor of the two evils and do this mod and it looks good. I wish him luck if it is just the swapping of the springs.
post #24 of 24 Old 02-17-2017, 11:00 AM
LumpyGrits
Cj
Have you look'd for any broken leaf springs, on the driver side?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
