The Jeep With No Name Teardown and Rebuild - Page 9 - JeepForum.com
 2Likes
post #121 of 2848 Old 09-14-2011, 01:59 PM Thread Starter
FLynes
1976 CJ5
Originally Posted by lucdog View Post
Take one of the bolts out that hold the bellhousing on. You'll probaley need 4 about 2 to 2.5" longer.
I believe I put the chain, were I'm pointing.
On painting the frame, it doesn't look quite as good, I feel brushing works paint in better.
Bill
Bill,
Huge help, thanks, I appreciate it.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #122 of 2848 Old 09-14-2011, 02:23 PM
SaskCJ7
1982 CJ7
Originally Posted by FLynes View Post
Mine is going right back down to the stock height with stock tires. No more lift for me.
Fred
Hmmm. Food for thought. Have fun!
The flame job on the front of my first Jeep would've been so much cooler had the flames not been real.
SaskCJ7 is offline
post #123 of 2848 Old 09-14-2011, 02:59 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Fred
Fred,
FYI, I'm with you on keeping the center of gravity as low as possible on these heaps.
That said, I've always liked the looks of a slightly larger than stock tire. That's why I went with the 2.5" Old Man Emu YJ springs. They gave me plenty of lift to run 32"/11.5's, but I didn't have to change any of the stock steering or driveline components.
As for drivability, I can confidently let go of the wheel on a straight-away, at highway speeds, and she'll track dead straight. Not that I make a habit of doing that, but it's nice to not have to constantly correct for wandering.
Anyway, I think your goal to win both "Ugliest" and "Jeep of the Month" is commendable. I'll certainly be following along on this one.
Matt
Matt1981CJ7 is online now
post #124 of 2848 Old 09-14-2011, 03:06 PM Thread Starter
FLynes
1976 CJ5
Thanks, Matt.
BTW, if you ever decide to get rid of that Warn winch, you can send it on down this way anytime
This is what I envision mine looking like, when it's done.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #125 of 2848 Old 09-14-2011, 03:36 PM
Matt1981CJ7
1981 CJ7
Nice...love the bandana!!
Matt
post #126 of 2848 Old 09-14-2011, 03:49 PM Thread Starter
FLynes
1976 CJ5
Brooke told me to go to Hell, when I told her I wanted to recreate the pic, once the CJ is done!
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #127 of 2848 Old 09-14-2011, 07:25 PM Thread Starter
FLynes
1976 CJ5
Okay, so here's the video of my axle....sorry for the poor quality, but you can still see what's going on. Anyone have any ideas as to why it's moving, and could this be the reason for the axle leaf spring twisting? I took the sound out, because it's really windy today.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #128 of 2848 Old 09-15-2011, 12:56 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Hard to say with the video. Might want to put it on a tripod or something.. of course, my eyes are tired right now...
As for the body lift and handling, I doubt that is why it is squirrelly. I have a 1" with maybe a smidge more lift on mine, and it handles fine. The new springs, bushings, solid frame, solid steering box mount, etc I think is what made mine ride so nice - to where I was averaging 65-70 today for maybe 40 miles. Same when I drove it to Chattanooga, I was going sped limit at least (65-70). I've hit 75 once or twice, but not intentionally. It handles like my Ranger now, where before it was all over the place, especially if you hit a dip in the road or bump. Trailer towing was a white-knuckle death ride. Now it is so smooth and easy,. you can almost forget it's back there.
I don't think a body lift would affect the handling very much. I think it may just be the worn or weak frame and suspension systems.
Rick
Cutlass327 is offline
post #129 of 2848 Old 09-15-2011, 05:25 AM
243
1978 FSJ Cherokee
I think it would look even sweeter with the top off and a set of BFG KM2's.
Dave's 78 Build
243 is offline
post #130 of 2848 Old 09-15-2011, 06:28 AM
waterdowg
In the video it looks like the entire axle tube is moving. Is that correct? If so my guess is the weld the holds the tube in place broke. Also looks like u-bolts are loose, but you may have done that. I believe the broken weld on the axle tube is the weak point in the AMC 20.
waterdowg is offline
post #131 of 2848 Old 09-15-2011, 06:42 AM
Matt1981CJ7
1981 CJ7
Originally Posted by 243 View Post
I think it would look even sweeter with the top off and a set of BFT KM2's.
A bikini wouldn't be bad either, but I agree, topless would be even better.
Matt
post #132 of 2848 Old 09-15-2011, 07:10 AM
mrmrezg
1982 CJ5
Notice her scarf? I wonder what it's hiding? Maybe her necklace? Could it be pearl?
mrmrezg is offline
post #133 of 2848 Old 09-15-2011, 07:37 AM
roadhog304
1973 CJ5
In you vedio it looks like to me that the u bolts are loose. i would change them out when you get that far. you can also check to make sure the welds on the perches are not broken as that would let it rotate also.
roadhog304 is offline
post #134 of 2848 Old 09-15-2011, 10:19 AM
richclan
1982 CJ8
the girl or the jeep???????????
82 CJ-8 Laredo 258cid Dana 300.T4, blk dia 3" lift w/shocks, YJ brake booster, ARB Air Lockers Front & Rear 456 ratio, Warn Hubs 1" boomerang lift shackles. Superior 1 piece axles. 1" Daystar body lift, contour elect. fans. Ricochet Rockers and Crusher Corners Build=
richclan is offline
post #135 of 2848 Old 09-15-2011, 10:55 AM Thread Starter
FLynes
1976 CJ5
No, the axle tube isn't moving....I think that the other concensus of the u-bolts being loose is why it's moving....fyi, I haven't touched them yet, so that worries me a bit.
I'm not allowed to use the new camera, because of greasy hands, so I have to use the 6 year-old HP...kids were doing homework, otherwise I would have had one of them hold it, while I wiggled the axle....no tripod, it got lost in the move from Maryland.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
258 teardown BlueOvalBud Jeep CJ Forum 17 03-04-2011 08:33 PM
4 minute jeep teardown<= posted multiple times-no need to share!!! Cutlass327 Jeep CJ Forum 6 09-13-2010 07:03 PM
For all the mechanics who thought you were fast watch this jeep teardown cj7jeep Jeep CJ Forum 8 09-13-2010 01:42 PM
Frame-Off Resto - The Teardown Sherms-CJ7 Jeep CJ Forum 9 05-10-2010 02:12 PM
77 Cj5 Teardown Update, Help!!! NCHornet Jeep CJ Forum 8 10-08-2006 06:36 PM
