The Jeep With No Name Teardown and Rebuild - Page 8 - JeepForum.com
 2Likes
post #106 of 2848 Old 09-13-2011, 11:08 AM Thread Starter
FLynes
1976 CJ5
Originally Posted by waterdowg View Post
Here you go
Thank you so much for the arrows....huge help! I love this site!
How do you get the rear crossmember/bumper off? Drill through the rivets?
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #107 of 2848 Old 09-13-2011, 11:13 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Ahhh...another CJ owner with hay-burners (horses)....must a disease, or something.
Matt
Matt1981CJ7 is online now
post #108 of 2848 Old 09-13-2011, 11:17 AM Thread Starter
FLynes
1976 CJ5
Matt
I think it must be! I call them hay burners too, because right now that's about all they're doing. Our yearling Quarter Horse is still too young to start training for Hunter Under Saddle, and the mares are just brood mares. The fourth hay burner is a breeding stock Paint Horse...he does have color, but it's on his pecker, and the last horse that APHA allowed to be registered with color on his wang was called "Search Me". We can use and sell him as a hunter jumper prospect, though.
Brooke likes to remind me how much I spend on the CJ, but I tactfully point out to her that her hay burners cost more.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #109 of 2848 Old 09-13-2011, 11:33 AM
243
1978 FSJ Cherokee
Fred,
I would use Rustoleum in a can before I used any spray paint on the frame, spray paint is thin there is a lot of waste.
I primed my homemade utility trailer with Rustoleum rusty metal primer http://www.rustoleum.com/CBGProduct.asp?pid=155 and their black paint http://www.rustoleum.com/CBGProduct.asp?pid=162 with a brush and roller. After sitting in the weather, completely exposed since 2006 it is still almost rust free except where the paint and primer have been gouged or scratched to bare metal.
Since I cleaned most of the rust off the trailer, this primer appears to be correct for the application and probably to your frame too http://www.rustoleum.com/CBGProduct.asp?pid=35
Dave's 78 Build
243 is offline
post #110 of 2848 Old 09-13-2011, 11:42 AM Thread Starter
FLynes
1976 CJ5
Originally Posted by 243 View Post
Fred,
I would use Rustoleum in a can before I used any spray paint on the frame. I primed my homemade utility trailer with Rustoleum rusty metal primer and their black paint with a brush and roller. After sitting in the weather, completely exposed since 2006 it is still almost rust free except where the paint and primer have gouged to the bare metal.
I was thinking Rustoleum rattle can, but you think brushing it is the better way to go....okay. What I want to know is what the OE finish was, i.e. flat, semi-gloss, gloss, etc...
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #111 of 2848 Old 09-13-2011, 11:47 AM
243
1978 FSJ Cherokee
Truthfully, if I was buying a new tub as you mentioned earlier, I would spray the frame for a better "looking" finish. I sprayed the Rustoleum high heat black (quart can) on my exhaust manifold and bbq pit with an HF gun and it turned out very nice. The level of finish is your call.
I suggested the roller or brush applied paint because it will provide a lot better protection than rattle can.
And it does not need to be Rustoleum, there are other paints from farm stores like TSC and others that provide emplement paint that would be as durable, or more durable than Rustoleum.
Dave's 78 Build
243 is offline
post #112 of 2848 Old 09-13-2011, 11:49 AM
waterdowg
Fred
I did not remove the rear crossmember. I only removed the tank. But, I would grind the head off the rivit, then punch it out with a center punch.
waterdowg is offline
post #113 of 2848 Old 09-13-2011, 07:53 PM Thread Starter
FLynes
1976 CJ5
Didn't get much accomplished today. Sawzall'd the exhaust off...mufflers were totally trashed. PB Blasted all of the bolts that are left on the frame, including the fuel tank area, got the fuel pump off and found it was leaking...no surprise there. Took the driveshafts off and then took the alternator bracket off, which is where I spent about a solid hour trying to get that bottom bolt off....real motherlover. I finally had to put a torch to the timing cover and hammer the crap out of it, then put a screwdriver in the back and hammer more. The impact wrench finally got it out the rest of the way.
I talked to a guy on the phone today, who worked for AMC on the Jeep assembly line...frame is supposed to be a satin finish, so that's one less mystery.
No pics, because there really wasn't anything interesting to shoot.
I will, however, take some video of the rear axle tomorrow...I'm a bit worried about it and want some opinions.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #114 of 2848 Old 09-14-2011, 12:03 PM
SaskCJ7
1982 CJ7
Did that body lift that was on there make your steering a little squirelly/terrifying, especially at high speeds? I have a jeep that I tore down that had the same size body lift on it and you didn't take it on high-speed roads cause chances were you wouldn't survive it. I was just wondering if the lift would have been the culprit. Great build, post lots of pics like the other guys said for those who rely on others build threads for their own projects. And PO's need to be shot and pissed on.
The flame job on the front of my first Jeep would've been so much cooler had the flames not been real.
SaskCJ7 is offline
post #115 of 2848 Old 09-14-2011, 12:06 PM
SaskCJ7
1982 CJ7
By the way, I would never call a jeep "ugly", rather that she "has a good personality"!
SaskCJ7 is offline
post #116 of 2848 Old 09-14-2011, 12:14 PM Thread Starter
FLynes
1976 CJ5
Ummmm, terrifying is one way of putting it. Let's just say that my seats are brown now
For grins and giggles, one day, I decided to get the CJ up to as fast as I could....65MPH was what it said, but it felt like 125. It took every ounce of strenth I had to keep it going straight. Looking back on that, I should have been awarded my stupid sign, because I could have easily flipped it and killed myself.
I didn't even want to offer the body lift to anyone for free, because those things are just too dangerous, and I'd hate to be responsible for someone getting hurt/killed.
Fred
P.S. The cat pee is what made it ugly!
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #117 of 2848 Old 09-14-2011, 12:18 PM Thread Starter
FLynes
1976 CJ5
For all the JF gurus:
I'm pulling the engine this weekend...going to TSC and getting chain and Grade 8 bolts for the engine stand....two questions:
1) Where is the best place on the engine to attach the chain?
2) What size Grade 8 bolts do I need, to secure the engine to the stand?
Thanks.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #118 of 2848 Old 09-14-2011, 12:25 PM
SaskCJ7
1982 CJ7
When I was in the looking at/buying stages of my Jeep, the guy who was selling it (who was NOT the mad scientist who screwed everything up) told me that another fella was coming to look at it. The seller lived 2.5 hours away from me, so I couldn't come look at it til that weekend, and in that time he was gonna show it to this guy. So I guess this guy comes over and his teenage daughter is with him. He checks it out, the seller gives him a bunch of info on the jeep, and everything looked good. So the guy then says to his daughter "So, what do you think? You want this one?". Right there the seller chimes in and asks "This is for her?" The guy says "Yeah, she just turned 16 and this is her present.". The seller then says "Then I'm sorry there is no way I'm selling you this thing. The SECOND you don't respect this vehicle it will 100% guaranteed kill you." And that was that. And I wound up driving it the 2.5 hours home (felt more like 10) and was white-knuckle terrified the whole time. So I'm hoping that by changing to a 4" susp lift she'll steer a bit better.
SaskCJ7 is offline
post #119 of 2848 Old 09-14-2011, 12:35 PM
lucdog
lucdog's Avatar
1980 CJ5
Thanks.
Fred
Take one of the bolts out that hold the bellhousing on. You'll probaley need 4 about 2 to 2.5" longer.
I believe I put the chain, were I'm pointing.
On painting the frame, it doesn't look quite as good, I feel brushing works paint in better.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #120 of 2848 Old 09-14-2011, 12:59 PM Thread Starter
FLynes
1976 CJ5
Mine is going right back down to the stock height with stock tires. No more lift for me.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
258 teardown BlueOvalBud Jeep CJ Forum 17 03-04-2011 07:33 PM
4 minute jeep teardown<= posted multiple times-no need to share!!! Cutlass327 Jeep CJ Forum 6 09-13-2010 06:03 PM
For all the mechanics who thought you were fast watch this jeep teardown cj7jeep Jeep CJ Forum 8 09-13-2010 12:42 PM
Frame-Off Resto - The Teardown Sherms-CJ7 Jeep CJ Forum 9 05-10-2010 01:12 PM
77 Cj5 Teardown Update, Help!!! NCHornet Jeep CJ Forum 8 10-08-2006 05:36 PM
