The Jeep With No Name Teardown and Rebuild - Page 2 - JeepForum.com
 2Likes
post #16 of 2848 Old 09-04-2011, 07:55 PM Thread Starter
FLynes
1976 CJ5
Wouldn't you know the wind kicked up and I got an oil bath...battery on the camera went dead, but I got the carb, intake and crappy Heddman headers off too...that's all for today.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #17 of 2848 Old 09-04-2011, 07:58 PM
waterdowg
subscribed
waterdowg is offline
post #18 of 2848 Old 09-04-2011, 08:04 PM
MoC
Fun Day!!
MoC is offline
post #19 of 2848 Old 09-04-2011, 08:06 PM Thread Starter
FLynes
1976 CJ5
Originally Posted by 243 View Post
First in
Frederick, after three years on my build I can say that I would never attempt a project of this magnitude again unless I had the entire vehicle sandblasted by a professional. I wasted more time and money with wire wheels, flap discs and other creations stripping metal than I have on any other part of the build. Next time I will trailer the chassis to a shop, have it stripped and take it straight home and spray it with epoxy primer. Then I would do the same with the body after taking photos of the damage that would need metal repair.
Good luck with your project!
Given the shape of the body, I think a new one from Willys Overland is in order. The only thing from the body that's salvageable is the hood and maybe the grill. The driver's fender is from a 1984 Renegade...who knows what the passenger side fender is from.
There is a sandblaster in town, which is where the frame is going to go, and then it's going to get powdercoated by them, while it's there.
Thanks for the advice and input.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #20 of 2848 Old 09-04-2011, 08:16 PM
Hurricane4
Subscribed! Go Go Go!
The unbelievable we can do immediately . . . the impossible just takes a little longer.
Hurricane4 is offline
post #21 of 2848 Old 09-04-2011, 08:57 PM
VACJ7
VACJ7's Avatar
You got your work cut out for you Fred! Subscribed. Looking forward to following along.
Paul
'84 CJ-7 |
VACJ7 is offline
post #22 of 2848 Old 09-05-2011, 07:46 AM Thread Starter
FLynes
1976 CJ5
Paul, you ain't kidding!!! I woke up sore as hell this morning and a bit sunburnt! Whoever said 38 was the new 28 is full of crap, because I didn't feel like this, when I tore my '72 Suburban down 10 years ago.
I did make an interesting discovery, though. When I took the Carter YF off, I finally got a look at the serial number, which is 7039S. When I looked at my parts manual, I found that 7039S is for a 1975 model. This makes sense, since my fuel tank is also from a 1975, as it has the 6.5" filler tube and longer vent tube, so I think the carb is original. My CJ-5 was built in December 1975, and I think that they used leftover parts from '75 to build the first '76 models. The engine is stamped 811A07, November 7, 1975 258 1bbl. The EGR is also stamped 17050471 (looks like an AC Delco number), which is for a 1975.
I also took the time to see why the distributor was so out of whack, so I used JH's lengthy methodology to get the #1 piston to TDC...sorry Aaron, but I'm a KISS kinda guy; took me less than two minutes to do it...hardest part was turning the engine over...result is the damper is dead on, which made me happy, and the rotor fell right into place. The firing order was correct, so the PO must have just wired it, based on where the rotor was at the time. Prestolite might not be the preferred distributor, but I like it, because it reminds me of the old Dodge 360 distributor...you're either right on or 180* out, pretty hard to f*** up.
Going to Fredericksburg today with the wife and some friends...I really want to wrench some more and get the engine and tranny out, but good German food and beer is calling my name.
That's all for now.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #23 of 2848 Old 09-05-2011, 08:56 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Looks like a big project! Good luck, and enjoy the time with the kids! I hope they can stick it out with you, but I know how school schedules can really mess that up.
Just a question though. In post 4, the one picture looking at the rear axle from behind. Is the left spring perch twisted up from the spring? It doesn't look straight in the picture.
Rick
Cutlass327 is offline
post #24 of 2848 Old 09-05-2011, 09:09 AM Thread Starter
FLynes
1976 CJ5
Today's pics.
The intake manifold is stamped 11 7 75, so at least that's original too.
Prestolite distributor in the right position.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #25 of 2848 Old 09-05-2011, 09:25 AM
SKT
Count me in on following this build!
Just curious if this CJ has a sentimental value, as it seems to be in really rough shape for a full blown restoration similiar to Keith's?
SKT is offline
post #26 of 2848 Old 09-05-2011, 10:48 AM
Jim1611
Jim1611's Avatar
Hi Fred. I'll be subscribing right after this post.
Advice...treat very part as though it could be the very last original CJ part in the world. You've already started by taking pictures and that's a very big help, I can't say how many times I see things that I missed just by looking at a picure. I think you're doing good by having the frame blasted and powder coated too. Keeping it factory original is a great idea. Anytime you start adding a different engine or drivetrain you really increase the work.
Nice to see the family involved and glad the 3" body lift is going away. Enjoy the work Fred.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #27 of 2848 Old 09-05-2011, 02:24 PM Thread Starter
FLynes
1976 CJ5
No sentimental value, just an inexplicable need to put things back to the way they were. I can't fix myself, so it gives me satisfaction to fix what I can.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #28 of 2848 Old 09-05-2011, 03:01 PM
Skerr
Geeeez, Fred... I think it needs a bullet!
This is the winner of the UGLIEST CJ... isn't it? I think I can hear it sighing from here! I'm IN for the long haul!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #29 of 2848 Old 09-05-2011, 03:39 PM
brownbagg
1930 MK Compass
dude you got way to many pictures, you dont have to post every picture you take
brownbagg is offline
post #30 of 2848 Old 09-05-2011, 03:52 PM
SKT
Fred
Gotcha - I was just curious, thanks!
Best of luck, and again, I'm looking forward to following along!
SKT is offline
258 teardown BlueOvalBud Jeep CJ Forum 17 03-04-2011 07:33 PM
4 minute jeep teardown<= posted multiple times-no need to share!!! Cutlass327 Jeep CJ Forum 6 09-13-2010 06:03 PM
For all the mechanics who thought you were fast watch this jeep teardown cj7jeep Jeep CJ Forum 8 09-13-2010 12:42 PM
Frame-Off Resto - The Teardown Sherms-CJ7 Jeep CJ Forum 9 05-10-2010 01:12 PM
77 Cj5 Teardown Update, Help!!! NCHornet Jeep CJ Forum 8 10-08-2006 05:36 PM
