The Jeep With No Name Teardown and Rebuild - Page 106 - JeepForum.com
 2Likes
post #1576 of 2827 Old 03-22-2014, 01:21 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Fred,
Do you have an IR thermometer? If so, take some readings around the thermostat housing and the radiator. At least that will confirm whether you have an overheating problem, or if it's just a defective gauge.
I have the opposite problem at the moment. It's a chilly 20 degree day, today. I just took my Ol' Girl for a 30 minute drive and noticed the factory gauge barely got to the green line. My IR thermometer confirmed the gauge is accurate. It measured only 136 degrees at the t-stat housing. Normally it's right around 190. I suspect my t-stat is stuck in the fully open position. We'll see.
Matt
Matt1981CJ7 is offline
post #1577 of 2827 Old 03-22-2014, 01:25 PM Thread Starter
FLynes
1976 CJ5
No, I don't have an IR thermometer, Matt. I did pop the top on the rad and it's not bubbling and I can tell when the new thermostat opens and closes, so I'm not particularly worried about overheating, but I would like to know why the gauge is reading hotter than it should. I might take the speedo out and swap in another gauge to see if there's a difference....I have two or three others.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #1578 of 2827 Old 03-22-2014, 01:32 PM
seabass1858
1983 CJ7
you could verify the temperature with a mechanical gauge which is what i did for my oil pressure
seabass1858 is offline
post #1579 of 2827 Old 03-22-2014, 01:39 PM Thread Starter
FLynes
1976 CJ5
What is the proper running temp for a 258? My '79 L-82 Vette normally ran at 205°.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #1580 of 2827 Old 03-22-2014, 01:44 PM
seabass1858
1983 CJ7
i would say 195-210 range
post #1581 of 2827 Old 03-22-2014, 01:49 PM
Matt1981CJ7
1981 CJ7
Engine temps will vary depending where you take the reading. It's my understanding the engine should operate right around the t-stat rating, measured at the top hose connection to the radiator.
Matt
post #1582 of 2827 Old 03-22-2014, 07:58 PM
Skerr
On Clay's '79 258, and on my '85 258, there is a port on the pass side of the block for the temp sending unit... if that's what you were talking about the boss not being tapped? I'm guessing you have the same port??
What is an elevator bolt??
Kerrdog
Go Fish! <*////><
Skerr is offline
post #1583 of 2827 Old 03-22-2014, 08:17 PM Thread Starter
FLynes
1976 CJ5
I didn't take a look at the passenger side, but the temp wire goes right to the front, so I'm assuming that the sender is where it's supposed to be. I'll take a look tomorrow.
An elevator bolt is a round disc with a bolt welded to it, square at the base of the disc. I found mine at the local Fastenal store...the 5/16"-20 was a perfect fit for the track, but the 1/4"-20 was just a tad short....here's a pic.
Also, I don't know how I did it, but I took the speedo apart, took the temp gauge apart, blew on it and cleaned the thin resistor wires, put everything back together and the gauge is reading perfectly normal now.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #1584 of 2827 Old 03-23-2014, 12:46 PM Thread Starter
FLynes
1976 CJ5
Are the admins screwing with the site? I've lost my avatar, even though it shows in my options that it's there.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #1585 of 2827 Old 03-23-2014, 12:53 PM
Dadamsnv
1977 CJ5
I see it on my end.
I'm looking for a Scout II Dana 300. Drop me a line if you have any leads. Thanks
Dadamsnv is offline
post #1586 of 2827 Old 03-23-2014, 02:10 PM
Guy Smilie
Guy Smilie's Avatar
1978 CJ5
Originally Posted by Dadamsnv View Post
I see it on my end.
I don't see it.
Guy Smilie is offline
post #1587 of 2827 Old 03-23-2014, 02:21 PM
Dadamsnv
1977 CJ5
Originally Posted by Guy Smilie
I don't see it.
maybe it's the app versus the web?? I also see my avatar, but I didn't renew my subscription, so it shouldn't be there.
Dadamsnv is offline
post #1588 of 2827 Old 03-23-2014, 03:07 PM Thread Starter
FLynes
1976 CJ5
I see it on the app, but not the web.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #1589 of 2827 Old 03-23-2014, 04:55 PM
Skerr
I don't see your avatar. Check your PMs and see if you are limited to to 10. If you are then your membership "expired". I got bumped, twice! It got fixed both times, with Eddie's help.
So, an elevator bolt is the same as a carriage bolt?
And when I was talking about the port for the temp on the pass side of the block, I was talking mechanical gauge. Not sure why I thought you were going that way??
Kerrdog
Go Fish! <*////><
Skerr is offline
post #1590 of 2827 Old 03-23-2014, 06:48 PM Thread Starter
FLynes
1976 CJ5
It was the membership....never got a message for renewal though, weird.
My understanding is that carriage bolts have more of a rounded headed, vice the elevator bolt, which has a flat head.
No, electrical gauge is what I'm using.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
258 teardown BlueOvalBud Jeep CJ Forum 17 03-04-2011 07:33 PM
4 minute jeep teardown<= posted multiple times-no need to share!!! Cutlass327 Jeep CJ Forum 6 09-13-2010 06:03 PM
For all the mechanics who thought you were fast watch this jeep teardown cj7jeep Jeep CJ Forum 8 09-13-2010 12:42 PM
Frame-Off Resto - The Teardown Sherms-CJ7 Jeep CJ Forum 9 05-10-2010 01:12 PM
77 Cj5 Teardown Update, Help!!! NCHornet Jeep CJ Forum 8 10-08-2006 05:36 PM
