The Jeep With No Name Teardown and Rebuild - Page 10 - JeepForum.com
 2Likes
post #136 of 2848 Old 09-15-2011, 09:58 AM Thread Starter
FLynes
1976 CJ5
Originally Posted by Matt1881CJ7 View Post
A bikini wouldn't be bad either, but I agree, topless would be even better.
Matt
She does have tig ole bitties, huh? Wonder how she looks today?
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #137 of 2848 Old 09-15-2011, 12:07 PM Thread Starter
FLynes
1976 CJ5
I'm going to TSC today, to pick up the stuff I need to pull the engine...what length of chain do you guys recommend? I bought a nifty cherry picker, when it was on sale at HF, but I think I'm just going to use the tractor again, because it's proven its worth.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #138 of 2848 Old 09-15-2011, 01:51 PM
lucdog
lucdog's Avatar
1980 CJ5
Fred, instead of buying chain, get one of these, it comes with plenty of chain.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #139 of 2848 Old 09-15-2011, 01:58 PM Thread Starter
FLynes
1976 CJ5
Bill,
Where do I get one and how much is it? Not sure if the wife will be kosher with it...since she quit her job, we're now on a tight budget, and she's the banker.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #140 of 2848 Old 09-15-2011, 04:06 PM
lucdog
lucdog's Avatar
1980 CJ5
It came from Harbour Freight. Sorry don't remember the price.
Didn't your avatar come from The Iger sanction(can't even come close to this spelling) CUT THE ROPE
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #141 of 2848 Old 09-15-2011, 06:59 PM Thread Starter
FLynes
1976 CJ5
Had to go to Lowe's, to get the Grade 8 bolts....HD and TSC didn't have what I needed. Also, I'm glad I looked carefully at the block...the 258 has two different size bolts on it, 3/8-16 and 7/16-14.
I also took some pics today, because I have questions/concerns. The first two is of the front crossmember. The PO apparently welded the rear of the front crossmember to the frame, and the driver's side weld cracked off....was it supposed to be welded from the factory? The second two pics are of mystery holes...the passenger's side is the one with one hole and the driver's side has two, below the power steering bracket holes...what went in these holes?
Fred
Front Crossmember_001.jpg   Front Crossmember_002.jpg   Mystery Hole_001.jpg   Mystery Holes.jpg
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #142 of 2848 Old 09-15-2011, 07:02 PM Thread Starter
FLynes
1976 CJ5
Bill
I'll check out HF tomorrow.
My avatar isn't from The Eiger Sanction, it's from The Outlaw Josey Wales....you were close on spelling.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #143 of 2848 Old 09-15-2011, 07:26 PM
lucdog
lucdog's Avatar
1980 CJ5
The two holes on the intake side front are for part of the power steering pump bracket. the spark plug side hole, has 3 grounds hooked to it. As I remember, at least three of the 258's i've had were this way.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #144 of 2848 Old 09-15-2011, 07:38 PM Thread Starter
FLynes
1976 CJ5
Bill
Bill, if you look at the last pic, just above those holes are those two bolts, which is where I took the bracket off for my P/S bracket....lends more credence to the idea that my P/S might not be OE, so then the next question would be what should be bolted where the bolts are?
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #145 of 2848 Old 09-15-2011, 09:27 PM
lucdog
lucdog's Avatar
1980 CJ5
I think your are correct, about the top bolts for the PS brackets. I'll look again tomorrow when its not dark and cold.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #146 of 2848 Old 09-16-2011, 07:01 AM
Deuskid
really cool
Deuskid is offline
post #147 of 2848 Old 09-16-2011, 07:46 AM
lucdog
lucdog's Avatar
1980 CJ5
Fred, I was mistaken on the 2 holes in question. The top 2 are for the PS. I do have the bottom holes. One is higher than the other, and there's nothing there but dirt. This is on a "84" and "83" sorry about the error.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #148 of 2848 Old 09-16-2011, 08:42 AM Thread Starter
FLynes
1976 CJ5
Bill
No worries, mine were crudded up with dirt too....I wonder if maybe those holes are for accessories for another AMC model vehicle.
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #149 of 2848 Old 09-16-2011, 09:54 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Mine doesn't have anything in the 2 lower holes either, but I have a P/S system from an 83..
How did they mount the smog pump with P/S? I took my pump off when I put the P/S in it's place.. May have some thing to do with that?
Rick
Cutlass327 is offline
post #150 of 2848 Old 09-16-2011, 10:09 AM
lucdog
lucdog's Avatar
1980 CJ5
On the front crossmember, there are 2 rivits on the front bottom thru the frame. I don't see anything but weld on the firewall side.
Both pictures are passenger side. Have a great weekend.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
258 teardown BlueOvalBud Jeep CJ Forum 17 03-04-2011 07:33 PM
4 minute jeep teardown<= posted multiple times-no need to share!!! Cutlass327 Jeep CJ Forum 6 09-13-2010 06:03 PM
For all the mechanics who thought you were fast watch this jeep teardown cj7jeep Jeep CJ Forum 8 09-13-2010 12:42 PM
Frame-Off Resto - The Teardown Sherms-CJ7 Jeep CJ Forum 9 05-10-2010 01:12 PM
77 Cj5 Teardown Update, Help!!! NCHornet Jeep CJ Forum 8 10-08-2006 05:36 PM
