Jeep mechanic around Baton Rouge - JeepForum.com
post #1 of 11 Old 08-18-2014, 10:42 AM Thread Starter
cgstrickland16
All,
I recently bought an 85 CJ-7. I admittedly know little about these Jeeps. I'm having a radiator issue that I'd like someone to look at. Also have some other possible issues I'd like to have addressed. Does anyone have any shops they recommend in the BR area that know how to work on Jeeps?
Thanks!!
cgstrickland16 is offline
post #2 of 11 Old 08-20-2014, 08:45 AM
lsukevinc
1979 CJ5
as far as the radiator, bring it to a radiator shop. You may have more luck pulling it and dropping it off.
what other issues are you having? There are a few 4x4 shops here but they are more lift kit installers than repairs.
lsukevinc is offline
post #3 of 11 Old 08-20-2014, 10:03 AM Thread Starter
cgstrickland16
Originally Posted by lsukevinc
as far as the radiator, bring it to a radiator shop. You may have more luck pulling it and dropping it off. what other issues are you having? There are a few 4x4 shops here but they are more lift kit installers than repairs.
I ended up taking it to Jefferson Car Care and it turns out the water pump was the actual culprit. No other real issues other than the oil pressure gauge needle jumps around a bit. I'm hoping it's just an issue with the gauge, but it could be a major underlying issue. Not sure how best to approach it. Any advice would be appreciated!
post #4 of 11 Old 08-20-2014, 11:42 AM
lsukevinc
1979 CJ5
The original oil pressure gauges are notorious for failure. Go to a local parts place and get you a mechanical unit. You will have to buy a line kit as well. Disconnect your sending unit from your engine and hook your hose to your new gauge up temporally you see if it is getting the proper pressure. If everything checks out, install the new gauge. If not, you may need a new oil pump or something else could be wrong.
post #5 of 11 Old 08-20-2014, 03:13 PM
captkhaos
1980 CJ7
Oh yeah... I remember that oil gauge issue now that you mention it. Needle jumping up and down... changed the sending unit (expensive little sucker), changed the gauge, happened again and I went with a mechanical gauge. Don't waste a penny trying to fix the stock gauge.
captkhaos is offline
post #6 of 11 Old 08-21-2014, 10:31 PM
hunter1
1979 CJ5
CG for future there's a guy who has a 4x4 shop on/near airline close to Gonzales, he's a jeep nut. I have his card at office if u need
1979 CJ5, 258 straight6, Dana30, T-18a, Dana20, AMC20
hunter1 is offline
post #7 of 11 Old 08-25-2014, 11:03 AM Thread Starter
cgstrickland16
Hunter - that'd be awesome. Go ahead and send me that info just in case. Ya never know. Thanks.
post #8 of 11 Old 08-25-2014, 11:17 AM
lsukevinc
1979 CJ5
it is probably searchers 4x4 he is talking about. They can fab stuff and install lifts etc. I don't think they are much of a mechanic shop but he could refer you. The owner Philip is a super nice guy.
post #9 of 11 Old 08-25-2014, 12:06 PM Thread Starter
cgstrickland16
Awesome. Thanks for the info.
post #10 of 11 Old 08-26-2014, 08:58 AM
hunter1
1979 CJ5
Yep that is Searchers... He had a few old Jeeps at his display at a Jeep run function I attended, and it was informative to talk to him. He was very energetic and seemed a very nice fellow.
He admitted he subs out moderate to serious engine work, and prefers what lsukevinc mentioned....maybe fab work, etc. Don't quote me, but I thought he mentioned he's owned a whole bunch of Jeeps over time.
Anyway.. FYI.
hunter1 is offline
post #11 of 11 Old 08-26-2014, 02:39 PM Thread Starter
cgstrickland16
Definitely good to know.
Thanks again.
