Jeep keeps dying- fuel problem with video - JeepForum.com
post #1 of 4 Old 01-07-2012, 07:08 PM Thread Starter
clerihew82
1977 CJ5
I have a 77 cj5 with a 258 engine. I have been out the last 2 times and have been stranded both times. I'm not quite sure if it is my fuel pump or what is going on. I replaced my tank and sender a few months ago so that may have a hand in my issue. It will run fine then all of the sudden it dies. In my clear fuel filter it just doesn't look like it is pumping enough fuel. Possible fuel pump or pull the tank again and see if there is a kinked hose? I have had the Jeep for about 14 years and i have never changed the fuel pump.
I posted a link to a video i took of the fuel coming into the clear fuel filter
Click the link below
clerihew82 is offline
post #2 of 4 Old 01-08-2012, 10:55 AM Thread Starter
clerihew82
1977 CJ5
no ideas?
post #3 of 4 Old 01-08-2012, 10:59 AM
Shiftace
1977 CJ5
Does your oil smell like gas?
Fuel pump is my guess.
Originally Posted by gpets View Post
...it is perfectly acceptable to take a sawzall to anything you can't figure out, that is how we all learn.
Shiftace is offline
post #4 of 4 Old 01-08-2012, 11:21 AM
skizriz
1978 CJ7
Looks like you are starving for fuel.
Did you replace the rubber fuel lines lately? Ethanol in today's gas really eats up old fuel lines from the inside out.
Fuel pump? Cheap and easy to change.
Leaks in any fuel lines? Connections where they clamp to the steel lines are a common area.You will suck air instead of fuel.
Rusted pin holes in the steel lines?
Long enough pickup tube on the new sending unit?
Plugged vent tubes?? Remove the gas cap to see if you hear it suck in air.
skizriz is offline
Jeep is literally dying on me!!! usmarine3521 Jeep CJ Forum 6 10-05-2011 07:59 PM
cj7 idleing and dying problem caigen Jeep CJ Forum 6 09-27-2011 09:25 PM
Dying Fuel Pump or....? _Kyle_ Jeep CJ Forum 18 01-24-2010 09:37 AM
idle problem? fuel issue? PLEASE HELP NEED MY JEEP!!!! Brg0012 Jeep CJ Forum 2 11-06-2009 12:51 PM
New Battery, but Jeep still dying overnight cam-shaft Jeep CJ Forum 9 06-23-2005 10:26 AM
