Jeep heat - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jeep heat
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueSave 5% Off Of All Orders In August - Promo Code
Unread 07-21-2015, 01:46 PM   #1
JeepdaddyRC
1983 CJ5
Jeep heat
Purchased an 83 CJ with OEM heavy duty cooling (3 core radiator, fan shroud, fan clutch). Lots of heat comes off the engine bay while driving and when stopped. Two seperate OEM gauges indicate normal operating temp. My 79 CJ with standard cooling does not give off this heat. Is this a result of the heavy duty cooling system and more efficient radiator, or a symptom of another problem?
JeepdaddyRC is offline   Reply With Quote Quick reply to this message
Unread 07-22-2015, 08:56 AM   #2
JeepdaddyRC
1983 CJ5
Opinions and experience welcome here...
Unread 07-22-2015, 09:33 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
You have more parts holding the heat in place outside of the engine maybe? One of those if it ain't broke... scenarios.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 07-22-2015, 10:12 AM   #4
bob4703
1974 CJ5
Have you verified that the clutch fan is working properly? After 30+ years it may not be as efficient as when new. Also is your radiator 100% clean of sediment, and not partially clogged? In theory your fan should push cooler air from the engine compartment through the radiator to cool engine coolant. This is when you are driving at slow speeds and not enough outside air is forced through the radiator. Check the entire cooling system. It may be time to replace the clutch fan with an electric fan. If you mount it on the grill side of the radiator you'll draw in cooler outside air--except for this week where air temp here has been close to 90. Good luck!
If it has rollup windows and A/C it ain't a Jeep. It is a rebranded Dodge!
bob4703 is offline   Reply With Quote Quick reply to this message
radiator
