Jeep Gas Guage Broke - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jeep Gas Guage Broke
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRough Country Deals at JeepHut.comJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 04-12-2009, 01:03 PM   #1
TxJeeper20
1982 CJ5
i hace a 1982 cj 5 the gas guauge is shown full all the time i replaced the fuel sending unit and still show full the coolant guage shows cold even wen my jeep hot wat gives DO YOU KNOW AN EASY WAY 2 REPLACE BROKE ONE IS IT GAS OR TEMP GUAGE
TxJeeper20 is offline   Reply With Quote
Unread 04-12-2009, 02:47 PM   #2
John Strenk
John Strenk's Avatar
1976 CJ5
I would say it's a bad ground on the speedo housing.
See sig.
John Strenk is offline   Reply With Quote
Unread 04-12-2009, 05:35 PM   #3
TxJeeper20
1982 CJ5
you said in the articles the speedo bulbs wont work if there a bad ground well my turn signals work my brights signal works and i think the gauge light works but i dont at nite so i check tonight well i put a piece of wire on the guage housing nothing happend so i movedit over and toucheda terminal the guage started moving like it working and then stopped the fuse blew so do i have a short is my regulator bad where do i attach an auxilarary ground
Unread 04-12-2009, 07:43 PM   #4
jp360cj
1977 CJ7
Easiest fix is to install an aftermarket gauge/sender for each
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal, Home built 4x4 tube bumpers, KC Daylighters
73 CJ6-Future project
jp360cj is offline   Reply With Quote
Unread 04-12-2009, 07:48 PM   #5
John Strenk
1976 CJ5
Well we should get a test light and see if the regulator is working. Also disconnect the sensor wires nd see if the gauge drops down again.
Unread 04-13-2009, 06:19 PM   #6
TxJeeper20
1982 CJ5
yes disconnecting the sending wire dropped the needle and what do i test to see if the regulator is working aree the gauges bad
