Jeep Engine Burning Oil? - JeepForum.com
post #1 of 15 Old 07-08-2007, 04:56 PM Thread Starter
mattmosman
I have a 79 CJ7 with an AMC 360 motor in it. The problem I am having is it seems like I am having to fill it up with two quarts of oil every week when the oil pressure gauge barely reads and the oil dipstick barely shows a trace of oil . I didn't know if this was normal for this type of engine or not or if I should be looking at something else? It has it's usual leaks but nothing that should drain the thing in two weeks. I take it out to play every weekend but it isn't like I am excessively hard on it. Any suggestions on where to start or is this just normal for the engine type?
mattmosman is offline
post #2 of 15 Old 07-08-2007, 05:47 PM
bdmonist
WTF is that?
bdmonist's Avatar
2 quarts a week is a lot of oil. You're either leaking it or burning it, either way you need to find the problem and try to get it fixed.
Before I replaced my 360, I was leaking about 1.5 quart a month, and had some pretty good leaks, and it smoked like hell too.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #3 of 15 Old 07-08-2007, 07:32 PM
kavephish
1981 CJ5
X2....there has to be some evidence of where it is going........
kavephish is offline
post #4 of 15 Old 07-08-2007, 08:13 PM
Trapshooter
I have to agree with kavephish. The question is if the leak is static or dynamic.
What does the ground look like where you park? Is the engine leaking sitting in the driveway or only when its running?
If you are not seeing any blue smoke, take a look at the back of your rig. If you see oilly spots on the back you have a leak.
Good luck......
Trapshooter is offline
post #5 of 15 Old 07-08-2007, 09:18 PM
JarWithLid
Wow, two quarts / week? Well, if you're burning oil that fast, you're going to see blue smoke and smell something delicious. If you're leaking that fast, it should be easy to find. Get under your jeep and wipe down everything with a rag. Drive it around for a day or two and look to see where the leaking oil is populating, trace that back to the source.
Dude, two quarts a week is a lot.
1966 VW Beetle
1985 CJ7 *SOLD* :'(
2000 XJ
1982 XS650 Bobber
1966 Honda CB160 Race Project
JarWithLid is offline
post #6 of 15 Old 07-08-2007, 09:25 PM Thread Starter
mattmosman
defintely does not smoke at all. Also.....about 2 quarts every two weeks; not every week like mentioned before. I leave it parked in the garage on the cement floor and there are a few little drips as you would expect from a Jeep but nothing that would explain going through 2 quarts. I have crawled under it and looked all over and cannot really see anything out of the ordinary. Would it be possible (as mentioned) it is only leaking when driving...if so where would be a good place to start looking?
post #7 of 15 Old 07-08-2007, 10:06 PM
JarWithLid
So it's clean. So no oil is anywhere.
You're going to have to get dirty and rock a flashlight.
1966 VW Beetle
1985 CJ7 *SOLD* :'(
2000 XJ
1982 XS650 Bobber
post #8 of 15 Old 07-09-2007, 03:37 AM
Fropleyqk
Fropleyqk's Avatar
My 304 was leaking from the oil pan. Thin g is that itd only leak under pressure so at idle there was nothing. It was dripping from the front half moon so there was almost no sign of a leak. Can be tricky sometimes. Theres also that flourescent dye you can put in the oil to help find the leak. Any auto parts store should have it.
Fropleyqk is offline
post #9 of 15 Old 07-09-2007, 07:39 AM
diamatron
1978 CJ7
Can Timing effect burning oil at all. I am messing around with my timing lately trying to get my 304 to start easier. And it seems the more I retard the timing the more Oil i tend to burn.
diamatron is offline
post #10 of 15 Old 07-09-2007, 08:42 AM
twmattox
Clean the engine with some degreaser at the local car wash. You should then be better able to find leaks. IIRC there is a dye you can add to your engine oil that will make it glow under a black light...
twmattox is offline
post #11 of 15 Old 07-09-2007, 10:44 AM
JarWithLid
Not really. Burning oil means you are leaking oil into the combustion chamber(s) and it is igniting with your fuel. Timing adjusts at what point of your piston stroke the spark plug sparks, igniting gas.
1966 VW Beetle
1985 CJ7 *SOLD* :'(
2000 XJ
1982 XS650 Bobber
post #12 of 15 Old 07-09-2007, 03:01 PM
jakemary
1977 CJ7
rear main seal is my guess. there fun i did the one on my 77 cj-7 304
jakemary is offline
post #13 of 15 Old 07-09-2007, 05:18 PM
chromegrille
1947 CJ2A
what oil are you using, muti-grade ?
chromegrille is offline
post #14 of 15 Old 07-10-2007, 10:16 AM Thread Starter
mattmosman
shell 5w-30
post #15 of 15 Old 07-10-2007, 02:44 PM
evil-ant
no smoke?, I guess your lucky, even when I get oil leaking out of a oil fill cap, it tends to somehow find it's way down on to the exhaust or something hot and burn, if it's leaking under load and not idle, you should degrease the entire engine and do a drive with it, if nothing shows, go and get a bilge diper, they sell them at many auto and marine part stores, it is designed to soak up oil in the bilge of the boat. zip-tie it under the engine and go for a ride. If it leaked then it will catch it and show from where. If that doesn't do it, let it cool and open the radiator cap, oily?, bad head gasket possibly
evil-ant is offline
Burning oil! trueprimitive Jeep CJ Forum 0 08-13-2009 09:51 PM
U-Joint Burning HELP! bulljeeper Jeep CJ Forum 9 04-28-2008 06:48 PM
im burning something 1979CJ7 Jeep CJ Forum 14 08-10-2007 08:48 AM
Burning up Distributors BESRK Jeep CJ Forum 7 02-20-2007 07:14 AM
burning oil in engine joe johnson Jeep CJ Forum 0 02-03-2005 05:45 PM
