jeep dies on a declone? - JeepForum.com
post #1 of 20 Old 09-27-2014, 12:59 PM Thread Starter
davegt
1983 CJ5
Ive tried searching this and did alot things I read. Cant seem to find the problem. Whenever im on a decline my jeep just wont staying idling, it just bogs down and dies. Runs fine when driving.. just seems as though the idles is directly related to gravity?? I have a 258 with Motorcraft 2150, new vac lines, new fuel fliter, checked timing, set idle screws, 2 even squirts out of the venturi, Vacuum gauge reads between 18 - 20 it does fluctuate between. Any thing I can look at?
Edit..declone..haha decline
davegt is offline
post #2 of 20 Old 09-27-2014, 01:34 PM
Mike Romain
First thing that comes to mind is the float level.
Mike
Mike Romain is offline
post #3 of 20 Old 09-27-2014, 02:41 PM
swatson454
1983 CJ7
I concur. The fuel is likely pushing forward and exposing the jets.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #4 of 20 Old 09-28-2014, 10:23 AM Thread Starter
davegt
1983 CJ5
I checked the float. Set to specs. Maybe fuel pressure?
davegt is offline
post #5 of 20 Old 09-28-2014, 10:35 AM
Mike Romain
How old is the filter?
Mike
post #6 of 20 Old 09-28-2014, 10:39 AM
bulldawgburns
1977 CJ5
The "declone" word in the title had me scared, I am still learning this while restoring mine... And thought that there was some new problem that I haven't read about yet!
my hypocrisy knows no bounds
bulldawgburns is offline
post #7 of 20 Old 09-28-2014, 04:28 PM Thread Starter
davegt
1983 CJ5
Filter is brand new
davegt is offline
post #8 of 20 Old 09-28-2014, 04:55 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Fuel tank venting properly?
Matt
Matt1981CJ7 is online now
post #9 of 20 Old 09-28-2014, 05:45 PM
LumpyGrits
Filter return line at the 12 o'clock position?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #10 of 20 Old 09-28-2014, 06:25 PM Thread Starter
davegt
1983 CJ5
Filter is in the 12 pos.
davegt is offline
post #11 of 20 Old 09-28-2014, 06:32 PM
LumpyGrits
Clarify this-'decline' as in back down the hill??
Is so-Lower you fuel level in the carb's bowel 1/8-3/16".
LG
post #12 of 20 Old 09-29-2014, 06:04 AM Thread Starter
davegt
1983 CJ5
It only happens when I go down a hill. I have the float set to specs, but I think im going to play with it a bit. May need to hold more gas in the bowl.
davegt is offline
post #13 of 20 Old 09-29-2014, 06:40 AM
richclan
1982 CJ8
i put the float @ 9/16 and put a float spring in mine.. couldnt be happier with it.
http://www.jeepforum.com/forum/f8/19...mbler-2537162/
82 CJ-8 Laredo 258cid Dana 300.T4, blk dia 3" lift w/shocks, YJ brake booster, ARB Air Lockers Front & Rear 456 ratio, Warn Hubs 1" boomerang lift shackles. Superior 1 piece axles. 1" Daystar body lift, contour elect. fans. Ricochet Rockers and Crusher Corners Build=
richclan is offline
post #14 of 20 Old 09-29-2014, 07:08 AM
Mike Romain
I think I would be checking the connections on the coil out. I have seen that harness shift on angles causing cut outs.
Mike
post #15 of 20 Old 09-29-2014, 10:32 AM
LumpyGrits
Again-Going forward or backing down a hill??
Backing down, this is a common issue. Like I said-Set the float lower.
IF you do have it set correctly. You have PLENTY of fuel in the bowl. Probably, to much fuel.
LG
