The Jeep died again... HELP! - JeepForum.com
post #1 of 5 Old 05-06-2013, 06:52 PM Thread Starter
Davis77Cj
1977 CJ7
the jeep is a '84 cj7
The jeep is bone stock minus the PO "helping" it.
About 3 monts ago the ECM died and was replaced which put her back on the road better than before. This morning however it died again, I am at a loss because the ECM shouldn't have died this soon. As well it is accompanied by new symptoms other than from before. The jeep floods on the first crank without the throttle being touched Also the battery terminal (pos) started arcing like crazy, throwing the gauges into a fit.
I am at a loss and any help is greatly appreciated!
Only in America do you have the God given right to be loudly opinionated about something that you are completly ignorant of.
Davis77Cj is offline
post #2 of 5 Old 05-06-2013, 07:22 PM
BagusJeep
1981 CJ7
The ECM could have died in 3 months, repro pattern parts are rubbish.
It is a 1984, so has it been Nuttered or is it still run by the computer? If so, is the IGN LPS fuse working? This little bitty fuse can knock out the ignition as the CEC computer filters and alters the signal from the pickup in the distributor before it gets to the ECM. No fuse, no voltage, no computer = no spark. I attach a fuse box diagram.
The battery terminal arcing is because it is worn out / corroded / loose. You need to take it apart and clean it up and fix it. This will turn the gauges on and off.
The carb flooding could be completely unrelated. If it is a BBD, when was the last time you took the top off and checked the float levels and inlet valve? It is a 10 minute job when you know what you are doing. It will run without the top on, allowing you to check the valve is topping the flow and the float is preventing excessive petrol levels in the carb, the main causes of flooding. If you have an electric pump, it could be doing it without cranking. If it is just a choke issue then you need to set up the choke mechanism, see Jeephammer's old posts.
The thing to check though is the ignition for spark. Take off one of the spark plug leads and put an old spark plug in there and hold it on to the block. Get a buddy to swing the engine, is there a crisp regular spark?? If not follow it back to the coil to check for spark.
If you are getting no spark break out a 12V test bulb and some long leads. Hook one end to the battery negative. In Run does it glow dimly when connected to the coil positive (red with tracer)? In Start does it become Bright?
If you hav evoltag eta the coil disconnect the light green wore from the other side of the coil. Hook the etst bulb between this and the battery positive. Swing the engine, does it blink on and off?
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is online now
post #3 of 5 Old 05-06-2013, 08:45 PM Thread Starter
Davis77Cj
1977 CJ7
Thanks i will try the diagnostic methods you suggested this weekend. The jeep is still run off of the computer which will hopefully be changed soon. Also it does have spark (i think) I stuck a screwdriver in the end of the #1 plug wire to get it to spark over. it did shock the piss out of me lol I forgot and held onto the shank of the screwdriver and i didn't want to check it again.
post #4 of 5 Old 05-06-2013, 09:42 PM
RamblingCJ
I'm sure that didn't feel good. Use a spare plug next time and ground it somewhere on the engine. You should see a spark not feel it .
You can get another aftermarket ECM or you could just nutter it. I recommend the later and you can leave everything hooked up for inspections.
RamblingCJ is offline
post #5 of 5 Old 05-09-2013, 10:58 AM Thread Starter
Davis77Cj
1977 CJ7
Well i am happy to say that I went and got a new ignition box and some carb cleaner to start trying to figure out what was wrong with the jeep. So i laid the parts on the bumper and decided to attempt to start it one last time before i dove into it. What do you know it came to life and purred like a kitten . Why? I have absolutly no clue other than it must have heard me talking to my dad about a new truck and she was having a fit . So I have decided to leave well enough alone until I gather all of the parts that need replacing and do it all in one shot.
