Jeep coolant recovery tank? - JeepForum.com
post #1 of 15 Old 09-14-2009, 01:26 PM Thread Starter
bigpapanail
1974 CJ5
It seem every now and then I have my radiator hose overflow hose leak a good amount of coolant I assume this isn't normal??? is there supposed to be a recovery tank on this unit? I have had this jeep about a month and it seems like if it's not one thing it's another...I just changed out the water pump and the thermostat now this 74" cj5 304
bigpapanail is offline
post #2 of 15 Old 09-14-2009, 01:27 PM
CSP
No coolant recovery tank on a '74, but it's easy to adapt one from an auto parts store or one from another vehicle in the junkyard.
CSP is offline
post #3 of 15 Old 09-14-2009, 01:35 PM Thread Starter
bigpapanail
1974 CJ5
Does it help any??? or really have any purpose???
post #4 of 15 Old 09-14-2009, 02:20 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
Yes. It catches what the radiator spits out and sucks it back in when it cools off. Keeps you from losing the coolant onto the ground. Just get the fender-mounted unit from a later CJ (80's).
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #5 of 15 Old 09-14-2009, 02:25 PM
datmony
Real purpose simply being keeping your radiator full regardless of the temperature(aside from the environmental aspect). Heat in materials (coolant in this case) causes the materials to expand. In the case of the radiator this is pushing the extra fluid that will not fit anymore in the radiator because it has expanded out the tube. If you have a resevoir then when the radiator cools it will suck the fluid back into the radiator and keeps it full. They are cheap to pick up and will keep you from having to fill your radiator every so often and will keep a toxic substance from leaking out.
datmony is offline
post #6 of 15 Old 09-14-2009, 02:45 PM
47redwillys
1967 CJ5
I saw somewhere that someone used an Army sruplus aluminum canteen for this. It looked pretty cool. Anyway, Summit has some universal ones to look at.
47redwillys is offline
post #7 of 15 Old 09-14-2009, 03:02 PM
Fjguercio
1978 CJ7
get one at the junk yard too.
Also note the anitfreeze/water mix is poision for dogs, cats, animals. Just a tablespoon or two will kill most dogs. You have 2-3 hrs to get to the vet before its too late. Smells sweet and they will lick it righ up. So antifreeze is not a good thing to spill around the house.
FYI,
Fred
Fjguercio is offline
post #8 of 15 Old 09-14-2009, 03:20 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You also have to insure your radiator cap is compatible with a recovery tank. Early caps only sealed on the inside of the filler neck. Later recovery caps have a rubber seal on the inside and the top as well. The early caps are becoming hard to find due to being replaced, however, if yours has one, the tank won't work.
jeepdaddy2000 is offline
post #9 of 15 Old 09-14-2009, 06:40 PM
otterred
1976 CJ5
also the recovery tank is needed in some area's, state parks and such to avoid environmental damage. Nothing a zip tied Gatorade bottle to the grill won't handle.
otterred is offline
post #10 of 15 Old 09-14-2009, 06:41 PM
otterred
1976 CJ5
also the recovery tank is needed in some area's, state parks and such to avoid environmental damage. Nothing a zip tied Gatorade bottle to the grill won't handle. I installed one on a 76 just because of the previously mentioned fact.
otterred is offline
post #11 of 15 Old 09-14-2009, 06:47 PM
pscj5
1972 CJ5
not tryin to thread jack but i am having the same problem i am about to put a water pump on but i didnt think it was bad but it puts out steaming radiator fluid from the hose every time i take it out not fun sprayin fluid as i go think it could just need a bottle or does it sound like a pump thanks
If you get stuck it better be broke or you didnt hit it hard enough
pscj5 is offline
post #12 of 15 Old 09-14-2009, 07:02 PM
wellmax
first be sure you have a good radiator cap, I think my 84 cj requires a 14 psi cap.
had trouble on old chevy truck with reservior being too full, it was the cap, replaced cap and all was fine.
wellmax is offline
post #13 of 15 Old 09-14-2009, 07:09 PM
bigredisb
1979 CJ7
I have always been under the impression that besides the obvious environmental reasons that a full coolant system maintains a higher boiling point due to the lack of air and proper rad cap for pressure. So you might see a little better operating temps as well due to the fact that your system will now be full all the time.
1979 CJ7 aka "Christine" Build Thread:
2013 Rubicon Unlimited build thread:
bigredisb is offline
post #14 of 15 Old 09-14-2009, 07:31 PM
sbcranger
its actually the pressurization of the system that raises the boiling temp. it works out to be ~3 degrees per PSI. certainly works better with a full system, not to mention ill keep you from overheating when its full
sbcranger is offline
post #15 of 15 Old 09-14-2009, 07:59 PM
texasimport
1978 CJ5
I run a 20 oz plastic soda bottle in mine. For now at least it does just fine.
78 304-CJ5
texasimport is offline
Coolant Overflow tank CJ-7 304 V-8 boomvader Jeep CJ Forum 11 01-05-2010 12:35 PM
Should 85 Jeep CJ 7 have a coolant overflow? macg1777 Jeep CJ Forum 18 01-03-2010 01:34 PM
Started without coolant, now coolant in oil. Blown head gasket? bkkrehbiel Jeep CJ Forum 6 12-26-2009 07:22 AM
Still over heating: no coolant flow, boiling coolant CJATE Jeep CJ Forum 45 07-15-2009 04:24 PM
Coolant overflow tank... Goody1231979 Jeep CJ Forum 10 11-01-2007 08:34 PM
