jeep cj8 sputtering - Page 2 - JeepForum.com
post #16 of 19 Old 11-16-2011, 07:23 AM
lucdog
lucdog's Avatar
1980 CJ5
Do you drive the Jeep everyday? I ask because if the ignition module was going bad, it would get worse the more you drive. Until it won't run at all.
It does sound like the fuel pump. And like the module, will get worse as time goes by.Have you been under the Jeep, and looked for any wet spots in the metal line from the tank? And where the hoses connect. Remember all the metal and rubber lines are 30 years old, if they have never been replaced.
To rule out a problem with the fuel pickup in the tank, if it were mine. I would secure a 5 gallon gas can, with gas in it, to the area in front of the grill. Run a fuel line from the can to the fuel pump, see if it runs better. You shouldn't even have to drive it. IIRC it sputters at idle.
I assume you've checked everything I posted before.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #17 of 19 Old 11-16-2011, 09:40 AM
baldfatdad
1984 CJ8
Check the choke.
baldfatdad is offline
post #18 of 19 Old 11-16-2011, 10:05 AM
Noplainsdrifter
1974 CJ5
My guess would be bad Cap, rotor and or plug wires.
It's a Jeep Thing, Chrysler Doesn't Understand!
Noplainsdrifter is offline
post #19 of 19 Old 11-16-2011, 02:25 PM Thread Starter
jeep670
1982 CJ8
yeah it is my daily driver..an it did get worse the more i drove my jeep..
jeep670 is offline
