Jeep CJ7 - Lokar shifter question - JeepForum.com
post #1 of 4 Old 02-17-2009, 11:37 AM Thread Starter
Waltallshy
1982 CJ7
Do you have to drop the transmission to mount the tranny mount shifter brackets or can you get to everything bolted up? The Lokar looks like the ticket for my jeep.
Waltallshy is offline
post #2 of 4 Old 02-17-2009, 12:35 PM
gmakra
What trans are you running and which Lokar shifter? I would assume you would have to drop your skid plate and lower the back down a bit if your putting in for an Auto the manual should be able to be replaced just by removing the tunnel cover.
gmakra is offline
post #3 of 4 Old 02-17-2009, 12:41 PM Thread Starter
Waltallshy
1982 CJ7
That would help wouldn't it?
TF 727 trannsmisson 16 inch tranny mount shifter with link not cable.
post #4 of 4 Old 02-17-2009, 04:07 PM
jksull
I just put one on mine
You could do it with the tranny in place but you might be mad before you finish.
The skid plate will have to come off or you wont be able to reach all of the linkage.
Unless your arms are 4' long and have more joints than mine do.
Keep us posted I could not get park and low to work like I wanted.
I have it adjusted now but it does not want to come out of park because of the front connector arm angle.
Partly because of the shifter hitting my console in first gear and the dash in park
jksull is offline
Lokar shifter jeff214 Jeep CJ Forum 11 01-09-2010 03:15 AM
Lokar cable shift rescuetech Jeep CJ Forum 0 07-06-2009 06:58 PM
Lokar kick down BigTDog Jeep CJ Forum 5 11-29-2008 05:48 AM
Lokar Kickdown Adjustment ?s chadcarter Jeep CJ Forum 4 09-29-2008 07:54 AM
Lokar shifter and kickdown drespecki Jeep CJ Forum 15 11-15-2007 09:01 PM
