#31 | |
I am running stock yj springs on mine and did a soa at the same time. Very good road habits and awesome flex offroad. I still need to get the right shocks for mine but here is a picture of where it is right now.
96 ZJ 318, quadratrac, 5.5" lift, 33" BFG's, ravine rims, winch bumper, rock sliders |
#32 |
This is what im getting off of pro comp 4 inch shocks.<a href="http://www.flickr.com/photos/41682782@N04/3973210112/" title="IMG_0277 by Wyatt Gilbert, on Flickr"><img src="http://farm3.static.flickr.com/2657/3973210112_30d68a0d98.jpg" width="500" height="375" alt="IMG_0277" /></a>
<a href="http://www.flickr.com/photos/41682782@N04/3972442141/" title="IMG_0279 by Wyatt Gilbert, on Flickr"><img src="http://farm3.static.flickr.com/2607/3972442141_34f16b569a.jpg" width="500" height="375" alt="IMG_0279" /></a> |
#33 |
Hang onto it. Once you achieve some decent flex, you're going to need it.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers. '83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff. http://www.jeepskate.net |
#34 |
ive allways hade a deisent amount but nothing impressive will it get that much worse?
#35 |
excuse my ignorance......this is a good topic but what is SUA and SOA
#36 |
Lost and Not Found
SUA-Spring under axle. This is the stock location.
SOA=Spring over axle. It's placing the springs ontop of the axles.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage It's easier to get forgiveness than permision. Salad is what food eats!!! http://emptypocketsoffroad.org/ |
#37 |
thanks...now my next question is Soa is for getting more lift but does that also help with flex
#38 |
Basically, most of the mods that make your rig more trail friendly make it less road mannered. Soft, flexy suspension off road = lots of lean on curves & corners and avoidance maneuvers on road.
#39 |
It's often touted as a cheap way to get 5+ inches of lift, but unless you know what you're doing and can fabricate & weld, it ain't cheap. No, it doesn't help with flex in and of itself. Crap springs are crap spring regardless of which way the axles are mounted. You still must use a decent spring, preferably one built for an SOA application so that it will survive the negative arching to often comes during compression. General rule is to use a fairly flat spring. There's plenty of info on this topic all over this forum and all over the web, just spend a a little time searching & reading.
#40 |
if i could do it all again i would do a soa. but im not too worried about road maners as long as its not too scarry i come to peace awile ago that its not going to handle or brake well thanks for the help so far guys
#41 |
It'll handle and brake well if you make it handle and brake well. I don;t know where folks get this notion that they have to accept 70's/80's era performance from their rigs.
#42 |
im saying the 35s i have arnt low profile and i dont think im could pull a g on the skid pad yet! im just takein it for what it is its 37 inches to where i step in body roll could happen ... but aaha yea
#43 |
This is approx. how the same Jeep I posted before sits now on 35's (I've since put YJ springs on the front and swapped out the rears with RE 4.5 XD's & Currie shackles in place of the Superlift 2.5's & Daystar 1 3/4" lift shackles). With upgraded braking & steering systems it rides, flexes, handles and brakes just fine. I wouldn't whip it around a corner like a sports car (it *is* a lifted rig with a high COG), but I can confidently drive it with my pinky and stop on a dime.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
