Quantcast jeep cj7 flex - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > jeep cj7 flex
Old 09-24-2009, 08:39 AM   #16
78treehugger
Lost and Not Found
1980 CJ7
Not quite as good as BERSK but out of the box 3" CJ SUA. 1" BL
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
http://emptypocketsoffroad.org/
78treehugger is offline   Reply With Quote
Old 09-24-2009, 08:36 PM   #17
crcj7
i couldent tell you its eather ome or super lif cause the booties where yellow (know thats not a great way to tell) couldent see what the tubes looked like they where covered with black underlineing that would not come off . thought the flip is suppost to help the tire push its way over stuff easier . im geting a alright amount of flex now but i want to get more its possiable the green jeep is the poster child for why im not doing a soa
crcj7 is offline   Reply With Quote
Old 09-24-2009, 09:32 PM   #18
ksheffer08
1981 CJ7
holy ****, are your shocks maxed out?
ksheffer08 is offline   Reply With Quote
Old 09-24-2009, 10:03 PM   #19
80cj
80cj's Avatar
1980 CJ5
Originally Posted by crcj7 View Post
im trying to get as much flex as possiable without spending a lot ... i have heard that takeing the second leaf out will help im think of shackles to i like the tara flex revolvers and the z ones but to use bout of those is too much money for what they do i can weld and have a small collection of fab tools so i can do a bit of work ... the shackles i have now sorda rough but i can spin the bolts with a braker bar there not super tight they dont seem to move much when i flex any tips or ideas to gain some flex . its also my daily driver and has a 4 inch lift
I took the bottom leaf out of my old stock front springs (6 leaf factory heavy duty) and it helped the ride and flex. I originally pulled the 2 lowest leaves but ended up with too much spring wrap/axle hop. Make sure your shocks are not bottoming out and restricting travel.
80cj is online now   Reply With Quote
Old 09-25-2009, 09:21 AM   #20
jeepskate
All that'll tell you is what brand the shocks might be. You'd know if you had OME...the front would be converted to run 2.5" wide springs. Do you have the cheaper 'bend-over' spring clips or do you have the open ones with a sleeved bolt running across the top of the leaves? If you have the bend over style and the shocks match the springs, you probably have Superlift. You can loosen those clamps and it'll make quite a difference...that's how I had mine and I've done it for a couple of other guys who had flex issues with otherwise middle of the road springs. This is how mine used to be with 2.5" Superlift Super-ride springs, 1/2" Tomken shackles with greasable bushings & 32's:
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote
Old 09-26-2009, 11:19 AM   #21
crcj7
Thanks that's what I will try today looks good
Old 09-30-2009, 07:53 PM   #22
crcj7
how do u loosen the spring clips it looks like mine are heated on or someting
Old 09-30-2009, 09:53 PM   #23
OlivergreenCJ7
1979 CJ7
heat them up and bend them up with channel locks. You could even even weld a small plate on top of the spring clips once they are opened up.
OlivergreenCJ7 is offline   Reply With Quote
Old 10-01-2009, 10:19 PM   #24
jeepskate
Chisel and a baby sledge or an air hammer with a chisel bit. You don't need to open them all the way, just loosen them a bit so that they aren't squeezing down on the leaves and preventing them from sliding.
Old 10-02-2009, 03:29 PM   #25
crcj7
okay . i can do this with weight on them right?
Old 10-02-2009, 03:30 PM   #26
jeepskate
Yes, you can.
Old 10-06-2009, 02:16 AM   #27
00bluedak
i just installed a set of swaybar disconnects yesterday. i have never seen my front axle flex so much. i can normally stuff the rear tires up in the tubs, but the front barely flexes at all. now, the front tires stuff all the way up in the fenders as well as the rear. best 85 bucks that i have spent on my suspension yet. btw, i have 2.5" lift and 33/12.50s.
Dave Thomas
President, Currahee Jeeps Club
WWW.CURRAHEEJEEPS.COM
00bluedak is offline   Reply With Quote
Old 10-06-2009, 10:08 AM   #28
jeepguy85
1987 YJ Wrangler
Where did you get your disconnects for 85 bucks?
jeepguy85 is offline   Reply With Quote
Old 10-06-2009, 11:24 AM   #29
crcj7
ill sell you mine i dont run a sway bar any more i dont feel a huge diff... i can clean it up n send you the whole sway bar and every thing for pretty good deal im in raleigh so it should be much shiping
Old 10-06-2009, 12:37 PM   #30
00bluedak
quadratec. total was $81.98 after shipping. they are rubicon express double disconnects.
Dave Thomas
Glock Forum
