Jeep cj7 3 inch body lift with fan cooling issues. Plz help - JeepForum.com
post #1 of 6 Old 02-18-2013, 08:40 PM Thread Starter
Patrick14
1981 CJ7
I put a 3 inch body lift in my cj7 but now my fan is hittingy rad. Any ideas what to do plz help
Patrick14 is offline
post #2 of 6 Old 02-18-2013, 11:00 PM
melancholy35
You need new motor mounts. Quadratec sells a set that will raise your motor. Just my 2 cents
melancholy35 is offline
post #3 of 6 Old 02-19-2013, 08:12 AM
hotrod351
1955 M-38
thats just one of the problems they dont tell you about a body lift. might get a smaller fan and add a electric fan in the front as a pusher. i have a similar problem having a 350 sbc in my old 55 cj. so small fan and big electric fan.
hotrod351 is offline
post #4 of 6 Old 02-19-2013, 08:36 AM
PERK
did you lower the radiator 3 " ?
PERK is offline
post #5 of 6 Old 02-19-2013, 11:24 AM
Tigerjeep79
1979 CJ7
Body lifts look good on paper! Easy and cheap, right? I'm not razzin' you, it's just that I've been there before.
Tigerjeep79 is offline
post #6 of 6 Old 02-19-2013, 11:59 AM
jeepwhore
A motor mount lift might help but I don't know of anyone that makes a 3" MML
^^ This. There should have been 4 brackets included in the kit. They are a piece of flat bar with either a hole on each end or a hole on one end and a stud welded to the other (spaced 3" apart). They get bolted to the grille where the rad mounts and then the rad is attached on the lower set of holes/studs. This solves not only the issue of the fan hitting but also corrects your coolant level.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
