Jeep CJ Weber 38 problem...need help! - JeepForum.com
post #1 of 3 Old 01-16-2012, 09:17 PM Thread Starter
TPaul83
1983 CJ7
Hey Guys,
Im new signing up to this site but have had tons of luck reading previous posts, etc. Now I have a question because I am out of ideas...
My Jeep/Engine: 83 CJ7; 258; HEI ignition; BRAND NEW weber 38, new plugs, new solenoid, new cap and rotor for HEI, new fuel pump, new fuel filter, new pcv...basically replaced all of that when I bought and installed the new weber. It ran like a champ for a few days - was probably a little rich - and wasn't 100% sure that choke was working properly - but other than that it was great. I had timed it to 8* and it idled hot at 650.
I Let it sit for about 2 days without running it. I didn't need to drive it but went to crank it anyway. It started perfectly, ran for about 2 minutes and then died.
NOW....
Jeep will turn over, runs VERY rough on a few cylinders (sometimes) and then putters out.
Extra info that might help:
I am not out of gas.
If it does start, it runs on what seems like maybe one or two cylinders.
It sometimes backfires before it dies.
Vapor is coming out of top of carb in between tries to start it.
I played around with fuel mixture screw - no help.
It won't even attempt to start up if I don't have my foot all the way on the gas.
I am out of ideas. It went from running perfectly to running like I have all but one of the spark plug wires unplugged. I have checked all the plugs, wires, etc...
Any ideas?... Thanks in advance
TPaul83 is offline
post #2 of 3 Old 01-16-2012, 09:44 PM
okjeep98
okjeep98's Avatar
1983 CJ7
I am not sure if this will help but your symptoms are just like mine were when my choke plate was closed. (had no power to electric choke) I found if I would hold my choke open with a piece of wire the jeep would finally cough and start and run fine. Then I would pull the wire holder after I warmed up. Eventually fixed it
83 cj7 4" lift 33 super swampers, Fuel Injected 258
If it aint broke, fix it untill it is.
okjeep98 is offline
post #3 of 3 Old 01-16-2012, 10:21 PM Thread Starter
TPaul83
1983 CJ7
tried it...didnt help :/
thanks for the reply okjeep...
so i went out there and tried to start it with the choke plate held open.
it seemed to try and start just a little better but did the exact same thing. rolled over several times and quit...
it did however back fire several times (big flame) out the top of the carb. scared the crap out of the girl helping me.
smoke/vapor is coming out of top of carb. putting a little bit of gas down the carb makes no change.
just a quick note: i a not 100% sure of how the choke plate is supposed to work, but it seems like it isn't working properly (again, from OP i said i didn't think choke was working correctly as it didn't run great until warmed up).
For instance, after holding choke open like you had said and trying it a few times, it is staying 100% open and not going back.
Maybe that is normal? either way, not starting, and not "coughing" and then running correctly...
thank you for the time to post though
any other ideas anyone?
TPaul83 is offline
carb , weber , won't start
weber tuning problem billyroy Jeep CJ Forum 5 12-03-2007 08:58 PM
Weber Carb problem RobP Jeep CJ Forum 13 11-27-2007 05:35 PM
Weber Carb Problem 84CJ7Mike Jeep CJ Forum 1 04-04-2005 09:24 AM
Weber rebuild problem twmattox Jeep CJ Forum 0 08-18-2004 02:16 PM
Weber problem Brillo Jeep CJ Forum 0 12-03-2003 12:54 PM
