Jeep build - JeepForum.com
post #1 of 3 Old 09-18-2008, 09:58 AM Thread Starter
ajstewart
Jeep build
So I took off the fenders hood wiring harness A/c & heater unit basically i have to un bolt the master cylinder and the body mounts and I will have the body off...
http://i414.photobucket.com/albums/p.../jeep010-1.jpg
http://i414.photobucket.com/albums/p.../jeep011-1.jpg
http://i414.photobucket.com/albums/p.../jeep012-1.jpg
http://i414.photobucket.com/albums/p.../jeep009-1.jpg
Once i get the body off im going to start prepping for por 15...can i por 15 parts of the drive train...im tossing the engine and tranny so my real question is the rear end...also can i paint the leaf springs shackles and shock mounts? any tricks on getting off the skid plates they are far gone and the bolts are un-moveable (Grind them)?
ajstewart is offline
post #2 of 3 Old 09-18-2008, 12:55 PM
SuB8HaVeN
Nice work, it looks like you have a solid foundation there. You can POR-15 anything your heart desires. I often apply it all over my hands and legs as well. The only thing I would be worried about is something like the engine or radiator where it may get hot enough to burn off the POR-15. Many people have applied POR-15 to their axles, frames, etc. The entire floor of my CJ is covered with it, my engine bay, gas tank and skid plate, etc. I really wish they would have had silver POR-15 a while back when I was tearing mine apart because I would have painted the entire tub with that stuff and shot some clear over it!
For the transfer case/transmission skid plate, I would get a breaker bar on those and see if you can get them to move. If the heads break off, you'll just have to drill them out and tap them and use bigger bolts. There are nuts in the frame that they thread into and the nuts are welded in place, so if you break one of those loose (unlikely), all I can say is good luck.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #3 of 3 Old 09-18-2008, 01:37 PM
YeloCJ
If the bolt breaks or the head strips out, you can drill a 3/4" hole on the outside of the frame, even with the bolt. Then you can either chisel out the nut and weld in a new one or just install a nut and bolt. After you're done you just have a patch welded over the hole.
YeloCJ, 360, 36's and Detroits f/r, T-18, Tera-low 20
YeloCJ is offline
Another Jeep CJ7 Build andresesquire Jeep CJ Forum 162 03-03-2016 07:09 PM
My jeep build :} Sedorbrian Jeep CJ Forum 0 06-20-2009 06:44 PM
Want To Build My First Jeep Dementius88 Jeep CJ Forum 18 02-13-2009 09:56 AM
78 Jeep CJ7 Build (on Going) Stan99 Jeep CJ Forum 7 06-22-2008 07:33 PM
Jeep cj7 401 build up jeffarcher401 Jeep CJ Forum 0 07-08-2007 08:58 PM
