Jeep (aka gangsta) lean - JeepForum.com
post #1 of 13 Old 03-07-2009, 07:22 PM Thread Starter
rkbell
1977 CJ5
I saw something two or three weeks ago on this but don't remember if their ever was a definative answer. Having nothing better to do today, I placed a level on my cowl (windshield frame is removed right now), then I placed it on the tail because it just looked like the Jeep wasn't level. Sure enough, the Jeep is 1" lower on the left (driver's side) than the right. It's in my garage (I built it and yes the floor is level) so the lean is somewhere in the Jeep itself. It's pretty easy to see with everything above the dash removed.
I know I need new spring and shackle bushings but they're equally bad on both sides. I seem to remember seeing a post where someone said that this is inherent in older CJ's, is this true? Anybody try to come up with a fix?
Thanks!
"We and the world will always be at war. Retreat is impossible. Arm yourselves for the conflict." Leif Enger
rkbell is offline
post #2 of 13 Old 03-07-2009, 07:23 PM
ubergeek
mine does it too, interested to see what everyone has to say about it.
ubergeek is offline
post #3 of 13 Old 03-07-2009, 07:38 PM
Coiz
1979 CJ7
If I remember correctly it is a common problem that had to do with the way they were strapped down for transport from the factory. Some are tweaked while others are not.
The dealers had a TSB to fix it by adding blocks between the rear axle and the spring to adjust the height for one side or the other. You would add a block to the side you want to lower. In the OP case a 1" block to the passengers side.
Mike
Coiz is offline
post #4 of 13 Old 03-07-2009, 07:50 PM Thread Starter
rkbell
1977 CJ5
Just the rear? how would that affect the front? Seems that something would have to happen to both ends on that side in order to even it out. Anyway, I'm not even sure my suspension is stock which I'm fixing to ask about in another post.....
rkbell is offline
post #5 of 13 Old 03-07-2009, 07:59 PM
Coiz
1979 CJ7
They may have put them in the front and back but I only remember seeing them in the rear. When you adjust one corner the opposite one will also change. So if you lower the right rear, the left front will raise slightly.
Mike
Coiz is offline
post #6 of 13 Old 03-07-2009, 08:12 PM
Bojeepus
i have this problem in my yj but its related to im a fat ars and for the vast majority of the last 80,000 miles ive been the only one in it
Bojeepus is offline
post #7 of 13 Old 03-08-2009, 09:07 AM
Mike Romain
Mine also has the lean. I also saw the post about the back corner being lowered. The block needed is a lot less than 1" though to bring the front corner up an inch.
Mike
Mike Romain is offline
post #8 of 13 Old 03-22-2009, 11:08 AM Thread Starter
rkbell
1977 CJ5
So I replaced the front spring eye bushings and also loosened the U-bolts and used a large bar clamp to pull the springs back to center then re-torqued the U-bolt nuts and what do you know, the Jeep sits level now. No blocks needed. Might work for some of you that are having the same problem also, might not. I was surprised at how much difference new bushings alone can make.
rkbell is offline
post #9 of 13 Old 03-22-2009, 02:38 PM
mcmud
1983 CJ8
Good to read your post. Its Great to read a happy report. You got it sittin bout right to please you. Seems like A lota CJ's got that old driver side front sag. Sad to say and to see.
That Front Toe Support carries the major portion of the reaction caused by twisting/vibration since the next forward grill mount is centered, as well as some portion of the users. An to that point IIRC most every one had a LH driver load but lots fewer had a rider along the roads. Windshield and some tops and some doors. and sadly enough the drivers bouncing about along the ways as we do. Hate to see it, the slit up the fender, that sag at the side but most of all at the kok eyed hood/grill scene.
Of course the first outboard supports share some as well. I find most all can be corrected at that #2 and possibly the #3 point. Not speaking to rust issues and the gaps there of, at all. The Twisting of the frame can compound the action at that #2 mount since the centered #1 is so far away. And to some less extent to that next outboard #3 mount.
The some times bent/split mounting point of the Toe Support could use a spacer/weld or such. Often bent upward well outside the bolt/captured nut location and can often be tweaked.
Ever been riding down a cool quite trail and heard/felt a unexpected snap? Look here.
Those frames set into a twist cause additional thoughts to be used. ...All sad but true.
At least this started out as a Congrats to you for that progress and you'll appreciate the effort for long to come.
Now the very thought of a change out with needed repair has depressed me so...Maybe see you passin by one day I'll look out for the newest other straight one.
mcmud is offline
post #10 of 13 Old 03-22-2009, 02:48 PM
Slawth
Master Rebater
Slawth's Avatar
1978 CJ5
I am on my 4th CJ and 2 of the 4 have had the lean. 1 of the 2 that did not have the lean had shims between the spring perch and the axle from the factory. Rigs were not always built by computerized machines- I have always considered the CJ lean one of the character flaws that I can live with...
Slawth is offline
post #11 of 13 Old 03-22-2009, 03:20 PM Thread Starter
rkbell
1977 CJ5
Slawth, I hear you. I had nothing better to do as I wait on parts so I figured I 'd dig in to it. The lean was MUCH more noticable with no top, windshield frame, etc on the Jeep.
Hey, Granite State is NH right? I grew up in that area (actually ME) retired here in GA after retiring from the military but alot of my kin live in NH (Weare, Hudson, Nashua, Manchester, etc). Looking forward to the next time I can get up that way and visit them. Doubt I'll be driving this ol' Jeep there though
rkbell is offline
post #12 of 13 Old 03-22-2009, 07:53 PM
computertech
1974 CJ5
The lean on my CJ5 is so bad, that I went mudding and plugged up the entire rear wheel well. The tire actually started smoking from the friction of the caked up mud. I pulled the wheel off and filled up an entire cardboard box with mud (a really big box too). On the side that's not leaning, the mud just falls right off. That's that stupid south Texas gumbo for ya. Sticks to EVERYTHING!
computertech is offline
post #13 of 13 Old 03-22-2009, 08:31 PM
Lifesgoodhere
Its a Jeep thing, nobody understands...lol
A Jeeper for life
Lifesgoodhere is offline
rich or lean mix? trueprimitive Jeep CJ Forum 13 08-28-2009 07:21 AM
The CJ-5 "Gangsta Lean" Bear-Olemiss Jeep CJ Forum 10 04-15-2009 04:21 PM
Jeep Lean! Etchandy Jeep CJ Forum 12 12-05-2008 11:05 PM
Lean or Vacuum Leak? socalcjer Jeep CJ Forum 6 08-13-2007 06:04 PM
78 CJ-5 BODY LEAN HEYWOOD Jeep CJ Forum 11 07-05-2002 04:48 AM
