Jeep 4.2 MSD ignition upgrade. - JeepForum.com
post #1 of 16 Old 04-25-2013, 11:59 PM Thread Starter
kovic
1983 CJ5
Hey Guys, I know a lot of you have upgraded your ignition. I plan on making my 1983 Jeep Cj5 a daily driver for a little while and am trying to figure out what I can do to make it more reliable.
4.2 liter, roughly 4000 miles, weber carb.
I already did the team rush, well upgrade the cap and roter, my on board computer was removed years ago all together.
Anyways, I read Jeephammer very good details on the updgrades, but I found myself still confused.
I am confused about CDI ignition, and MSD ignition, are they the same thing, or do they have to be done at the same time...
I know this is stupid but I am unsure.
I am also going to replace my coil, probably just the MSD blaster.
Anyways any help would be great, thanks
kov
kovic is offline
post #2 of 16 Old 04-26-2013, 05:59 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
MSD is just a particular brand of CDI (Capacitor Discharge Ignition).
Matt
Matt1981CJ7 is offline
post #3 of 16 Old 04-26-2013, 06:10 AM
steveojeepster
1978 CJ7
I did the Team Rush upgrades and installed the MSD 6A box and Blaster coil. Very happy with the performance. Tune your carb right and it'll start first turn every time.
78 CJ7 - Fiberglass Tub - 258, T18, Dana 44 Rear - York OBA - 8274 - 33 MTs - Team Rush & MSD
steveojeepster is offline
post #4 of 16 Old 04-26-2013, 07:47 AM
WindKnot
1977 CJ7
^^^This^^^
I've found the spark to be so hot I can frequently skip using my manual choke and it will still start up right away.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is online now
post #5 of 16 Old 04-26-2013, 08:27 AM
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
I used the Streetfire MSD with a savings of about $60 and it does VERY well also. The difference more than pays for your MSD Blaster 2 upgrade.
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
HALOjmpr is offline
post #6 of 16 Old 04-26-2013, 10:45 AM Thread Starter
kovic
1983 CJ5
Hey Thanks for the responses Guys, The 6al with the rev limiter is not to important with the inline 6 right.
Thanks for clearing that up
kov
kovic is offline
post #7 of 16 Old 04-26-2013, 10:58 AM
WindKnot
1977 CJ7
Right. Not needed. The 6A is just fine. As mentioned the Street fire(?) will also work fine, just not as hot of a spark. A little less expensive. I went with the 6A anyways. YOUR choice though, wiring is the same.
Also, DON'T waste your time buying those new fangled spark plugs made from unobtanium. Good old Copper plugs really do work best... and they're cheaper.
post #8 of 16 Old 04-26-2013, 11:21 AM Thread Starter
kovic
1983 CJ5
Ok cool thanks. One other thing, As I had mentioned before my onbard computer, i Think that is what it is, it sat above the air condition vent fried a few years ago and shop removed it. Is this going to interfere with he MSD upgrade, is it needed?
Thanks
kov
kovic is offline
post #9 of 16 Old 04-26-2013, 12:08 PM
scrapman
Thanks
kov
Nope, shouldn't matter at all.
scrapman is offline
post #10 of 16 Old 04-26-2013, 01:42 PM Thread Starter
kovic
1983 CJ5
Right on, thanks guys, can always count on you all to help me out as you have done many times in the past
Looks like ill be getting the:
MSD 6a p/n 6200
MSD blaster 2 p/n 8202
I need this to right : MSD adapter p/n 8869 http://www.ebay.com/itm/MSD-Ignition...1ca3fa&vxp=mtr
Does that look about right?
Thanks guys
kov
kovic is offline
post #11 of 16 Old 04-26-2013, 03:58 PM
steveojeepster
1978 CJ7
Lastly make sure you have good clean spark plugs. Webers can run rich if not tuned properly. Good luck
post #12 of 16 Old 04-26-2013, 04:23 PM Thread Starter
kovic
1983 CJ5
Yes, i have had plenty of troubles with my weber, but a lot of guys helped me out last year and I think I got it running pretty good. So the parts I listed, Are those the correct ones?
Thanks
kov
kovic is offline
post #13 of 16 Old 04-27-2013, 06:50 AM
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
Thanks
kov
They look right. The adapter is nice if you plan on going back to the factory setup later, but you can solder, heatshrink and tape and it will work fine too. I am never going back factory so I opted for terminal ends to the coil wires and hard wired the distributor.
HALOjmpr is offline
post #14 of 16 Old 04-27-2013, 10:03 AM Thread Starter
kovic
1983 CJ5
Thanks HALO,
I will probably do the adapter, and it looks like ill need the extension with that. I am not to good working with wires, I am not even sure where everything connects.
I also am going to replace my distributor, mine has a slight wiggle. Should I just get the stock replacement?
kov
kovic is offline
post #15 of 16 Old 04-27-2013, 10:46 AM
HALOjmpr
HALOjmpr's Avatar
1982 CJ7
Thanks HALO,
kov
With the rush upgrade the stock distributor does great. There are plenty who opt for aftermarket distributors instead of CDI. It really is a matter of preference from all I have seen with the 258. The setup you are talking about is with the stock distributor though.
HALOjmpr is offline
