jeeep won't STOP running - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > jeeep won't STOP running
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options! Jeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06
Unread 05-29-2002, 06:43 PM   #1
storm_pilot
gotta 73' cj-5 with the 232. checked timing, rebuilt carb, operating within temp limits, idle is set at 700, plugs are gapped right, all new ignition, but sometimes when i turn it off it will deisel and sometimes even spin backwards. any ideas? anyone else have this problem?
storm_pilot is offline   Reply With Quote Quick reply to this message
Unread 05-29-2002, 07:26 PM   #2
buddhasbomb
probably carbon buildup in motor causing this. the buildup gets sharp points on it and will glow from the combustion heat and act like a sparl pkug or glow plug.use a good engine cleaner to get rid ofthis. i use tl3 deposit removerfrom autozone.comes in a white bottle and works really well
buddhasbomb is offline   Reply With Quote Quick reply to this message
Unread 05-29-2002, 11:27 PM   #3
jeepdaddy2000
1971 CJ5
You might try readjusting the idle mixture screws,too rich a mixture can cause the engine to continue to run.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 06-01-2002, 10:00 PM   #4
AeroViper1
In my CJ there is something called the Anti-deisel soloniod...The book says that it prevents the continued running.
AeroViper1 is offline   Reply With Quote Quick reply to this message
