Jacking CJ5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Jacking CJ5
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 11-25-2015, 10:08 AM   #1
11BGUY
2004 XJ Cherokee
Jacking CJ5
Guys I have a new to me CJ that has a 6 inch lift. Needless to say the 18inches to frame means I can't get my jack under there or use my jackstands. What about under here where the shock attaches to the mounting plate and then put a jack stand to the right under the axle? Is this ok and what people normally do? I have a hi-lift that came with the jeep but have never used one.. Thanks
11BGUY is offline   Reply With Quote Quick reply to this message
Unread 11-25-2015, 10:19 AM   #2
11BGUY
2004 XJ Cherokee
This is what I was talking about
Unread 11-25-2015, 10:43 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
That is what I use.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 11-25-2015, 10:45 AM   #4
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
A floor jack would be a lot easier, and safer, than using a high-lift in this situation.
Matt
Matt1981CJ7 is online now   Reply With Quote Quick reply to this message
Unread 11-25-2015, 10:45 AM   #5
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by Mike Romain View Post
That is what I use.
Me too...
Get a good jackstand.
I like this style:
John Strenk is online now   Reply With Quote Quick reply to this message
Unread 11-25-2015, 04:50 PM   #6
Pathkiller
1974 CJ5
Spring under with springs that seem pretty flat, shackles that are close to stock length. I don't see 6" of lift there, but if you say so...
A hydraulic bottle jack under the spring pad should work fine. Always use jack stands if you're working under the Jeep. Even a cheapo hydraulic floor jack from Wal-Mart should work.
74 CJ5
Pathkiller is online now   Reply With Quote Quick reply to this message
Unread 11-25-2015, 05:15 PM   #7
rixcj
rixcj's Avatar
1979 CJ5
I use 6-ton jack stands just because they are taller than 3-ton stands...
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 11-25-2015, 05:27 PM   #8
y2k-fxst
1964 CJ6
Be careful with the Highlift jack, they will bite and bite hard! You should mess with it some before you need it to see how it works. They are very unstable when used for jacking-up a vehicle and can easily be tipped sending the vehicle slamming to the ground. When under pressure keep anything you care about (hands, arms, head, face, etc.) out from between the handle and the frame of the jack. They handle will fly up quickly and forcefully if your hand slips off of it. When lowering the jack once weight is off of it the traveler can drop suddenly to the ground so keep feet out from under.
A Highlift jack is a very useful tool but, must be used with extreme caution. For general duties such as changing tires or positioning for work definitely go with a bottle jack or floor jack under the axle.
I own a Harley and a JEEP, still some people can't figure out why I'm broke!
y2k-fxst is offline   Reply With Quote Quick reply to this message
Unread 11-25-2015, 11:23 PM   #9
BagusJeep
1981 CJ7
x2.
My high lift stays bolted to the CJ, it ain't going anywhere near lifting for maintenance.
I use a trolley jack and wooden block (12" square by 2" thick teak) just where you are pointing if I want to do one side or under the diff if I want to raise it evenly. In the workshop it is axle stands under, on the trail it is wheel and tyre under the frame but I never let my hands or legs or far worse my chest under a vehicle that can drop far enough to cause injury.
One useful variant on a lifted CJ is to jack it up, take the wheels off and lower it down to close to the ground. It makes working in the engine bay so much easier.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 11-25-2015, 11:28 PM   #10
11BGUY
2004 XJ Cherokee
Thanks guys for all the replies.. I haven't officially measured the lift its what the previous owner told me...
Unread 11-26-2015, 05:34 AM   #11
skizriz
1978 CJ7
I carry one of these I got at Tractor Supply. Wide stable base can be used on soft ground, built in jack stand, plenty of lift with my 35" tires, nice cradle for under the axle tube unlike a bottle jack. It's always the first jack we use while out wheeling, the High Lift jacks only get used for breaking beads on tires when needed, they are death traps.
78 CJ7.. 258.. TH400/Dana18.. SOA/stock YJ springs.. 35" General Grabbers.. Waggy 44s.. 4.88 gears...Spartan/Lockright...Fiberglass front to rear
skizriz is online now   Reply With Quote Quick reply to this message
Unread 11-26-2015, 06:16 AM   #12
Matt1981CJ7
1981 CJ7
If you are planning to do a lot of wrenching on your CJ, you really should get one of these.
Matt
Unread 11-26-2015, 06:53 AM   #13
keith460
Jeep. There's Only One
keith460's Avatar
I use a piece of scrap end round stock of steel for both a backing block for hitting objects with a hammer and use it as a spacer for the floor jack when jacking things that are too high.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote Quick reply to this message
Unread 11-26-2015, 07:18 AM   #14
SemperFiGuy
1980 CJ5
Attachment 2534226
That's pretty cool looking, does it really work as good as it looks. Going to investigate.
Sent from my SCH-I545 using Tapatalk
SemperFiGuy is online now   Reply With Quote Quick reply to this message
Unread 11-26-2015, 07:35 AM   #15
skizriz
1978 CJ7
Works very well. I use it everywhere. Its very stable and secure.
Had it for about 3 years and its the only jack I have now. I think it was only $29 when I first bought it, the price has gone up some.
http://www.youtube.com/watch?v=OjUABH8YMes
