J3229510 Distributor Condenser - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > J3229510 Distributor Condenser
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-11-2015, 05:46 PM   #1
j33ping
j33ping is offline   Reply With Quote Quick reply to this message
Unread 04-11-2015, 09:17 PM   #2
BagusJeep
BagusJeep's Avatar
1981 CJ7
There are various sources of radio interference in a vehicle, anywhere there is an air gap and current passing across you can get it. This includes the alternator as well as the distributor and plugs.
With an electronic ignition there are no contact breakers but there is still an issue with the air gap in the distributor interfering with the electrical circuits.
If you can hear a popping sound on the radio when the engine is running slowly you need to suppress the coil with a capacitor from the battery side of the ignition coil to a ground. This keeps the distributor noise from being conducted through the battery lead into the electrical system of the vehicle.
This is the capacitor you can see on the circuit diagarms of electronic ignitioned CJs of the late seventies.
In summary, you do not need it if no radio is fitted and it will not affect the electronic ignition.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1947 Willys CJ2A/3A/MB/M38 - Little Willy
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is online now   Reply With Quote Quick reply to this message
Unread 04-12-2015, 08:16 AM   #3
JeepHammer
Running On Empty...
1973 CJ5
Originally Posted by j33ping View Post
What purpose does this condenser serve exactly?
I'm trying to find out if its necessary without a radio installed or if it affects the electronic distributor in some way?
Does it hook into the red wire with black stripe coming off the ignition coil lead?
Thanks for info!
Depends on where the 'Capacator' ('Condenser') is located in the system.
The 'Condenser' in the distributor keeps electrical current from arcing over the breaker points when they open,
Making the breaker points last MUCH longer.
The 'Condenser' when mounted on the coil bracket, hooked to the Positive terminal on the ignition coil,
Is to cut back on radio interference,
The 'Condenser' in an HEI distributor is mounted next the module,
It's function is to cut down on radio noise.
JeepHammer is online now   Reply With Quote Quick reply to this message
Unread 04-12-2015, 08:38 AM   #4
j33ping
