J20 Steering Box Upgrade - Page 3 - JeepForum.com
post #31 of 48 Old 07-13-2010, 07:13 PM
1sik78cj7
1978 CJ7
CJFF29, Pics would be great!!!!
I'm still trying to get all the parts together.
God, guts, guns....without them we have no FREEDOM!
1sik78cj7 is offline
post #32 of 48 Old 07-13-2010, 07:16 PM
brownbagg
1930 MK Compass
all I did was buy a saginaw from a chevy car in a junk yard for twenty buck. I think it was from a monza
brownbagg is offline
post #33 of 48 Old 07-13-2010, 09:26 PM
1sik78cj7
1978 CJ7
Just spent another $82.00 (with shipping) buying a rock-tite HD steering gear mount on ebay. This upgrade is getting pricey!
post #34 of 48 Old 07-26-2010, 09:14 PM
1sik78cj7
1978 CJ7
Ok so I was lucky enough to win a bracket on ebay for only $10.50 plus shipping. So now all I need are the hoses and a pump pulley and I'll be ready to start installation!!
post #35 of 48 Old 07-30-2010, 11:57 AM
fast54vw
Originally Posted by bleoh View Post
Here is a picture of the difference I was talking about. The cap on the J20 is about 3.5" wide, the CJ's and other FSJ are only about 3". Most of the time the chain stores will give you the smaller one.
http://members.cox.net/pmountsoa/J20Box/01sidexside.JPG
what box is on the right in your pic?
i have been looking at boxes to do the conversion on my cj and every box i come across measures 3 7/8". i went to my WD supplier for my work and checked out and measured 18 gear boxes for jeeps, chevys, buicks etc, you name it and they all measured 3 7/8". i have yet to find one that is small like the one in the picture.
so your pic of the large and small gear box has me wondering.
and so everyone knows, every saginaw gear box will bolt into any vehicle (that uses saginaw box) as long as
1.the input shaft splines are correct
2.the fittings are the corect style (flare or o-ring)
3.check if you need 3 or 4 mounting bolt holes
all three of these boxes had a 3/4 30 spline input shaft on them
the pitman arm shaft is the same size and spline count on every power box i checked.
So is there another way to id a J-20 box? i have bought 3 boxes in the last 2 days and honestly i cant see any major external differences between
the 78 j-20 box had flare fittings and had the nipple on the input shaft
the 85 j-20 box had o-ring fitting and the nipple on the input shaft
the 90 cherokee/wagoneer box o-ring fittings and no nipple on the input shaft
fast54vw is offline
post #36 of 48 Old 07-31-2010, 02:02 PM
bleoh
Fast, I am not sure what is on the right, I found that pic on the net.
bleoh is offline
post #37 of 48 Old 08-17-2010, 02:46 PM
1sik78cj7
1978 CJ7
got one of the hoses. I've been looking at the belts on my engine and I'm trying to figure out how to route them once I add the p/s pump. I still have the smog pump on mine cause NV requires smog checks on registered vehicles newer than 68 or 69 (can't remember which but it doesn't matter anyway since my Jeep doesn't qualify) So if anyone has p/s and a smog pump can you please post a pic, so I can see how they mount up and how to run the belts. I've been through my chilton's and can't find anything about it.
post #38 of 48 Old 05-11-2011, 07:27 PM
1sik78cj7
1978 CJ7
If anyone is still subscribed to this (or even cares) I finally started the upgrade, so I started a new post under "258 manual to power steering upgrade with smog pump and J-20 gear box."
post #39 of 48 Old 05-20-2011, 08:38 PM
steveojeepster
1978 CJ7
Big fan of these threads. I'm thinking of upgrading my leaking and sloppy CJ stock P/S box to a J20 box. Couple of questions... 1) will I need to upgrade the P/S pump as well? 2) can I still use the same drop pitman arm that I have mounted on the current box? 3) I'd also like to use a borgenson steering shaft, I get the feeling though that the input spline differential might foul me up here, correct?
steveojeepster is offline
post #40 of 48 Old 05-23-2011, 02:31 PM
CSP
1. Stock pump works
2. Pitman arm you have works
3. Call Borgeson and tell them the diameter and spline count of the steering box before ordering. They will get you the correct joint at the bottom of the shaft.
CSP is offline
post #41 of 48 Old 05-24-2011, 08:02 PM
dub870
1981 CJ7
I am trying to use a J20 box to upgrade my 81 CJ7 from manual to P/s but the reman box I got from O'Reilly auto parts only had 3 mounting bolt holes. I think I will take it back and get one with 4. I am going through the trouble and spending the money on a aftermarket HD mounting bracket I may as well get all the bolt holes!
dub870 is offline
post #42 of 48 Old 05-25-2011, 07:56 AM
bleoh
The chances of you getting an actual J20 box are slim. All they care about is if the box will work in the application you asked for.
bleoh is offline
post #43 of 48 Old 09-23-2011, 02:52 PM
Rollbar
1984 CJ8
Originally Posted by jeepwhore View Post
The J20/FSJ boxes mount exactly the same way but the spline count and diameter of the input shaft is different. A J20 box with power steering has the same spline count and dia. as a CJ box with manual steering (or so I've read). So a bell coupler from a power CJ column won't work on the J20 box.
So I can use my drop pitman arm I have for a manual box to fit correct.
I also have a 360 P-steering pump, should work.
<----Click
<---- Click
Rollbar is offline
post #44 of 48 Old 11-04-2012, 04:54 AM
steff
Originally Posted by JeepHammer View Post
Late '70s early '80s FSJ or J-truck steering boxes,
Variable rate, where CJ had single rate,
They are heavier duty than the CJ boxes,
And they bolt right in to common power steering box brackets...
You will have to find/fabricate the power steering pump brackets for your engine,
Other than that, all you need is hoses...
Some people will need a conversion coupler or to change pitman arms for the right size, but that's cheap compared to the $800 and up for the 'Premium' boxes everyone wants to run,
And if you want to add ram assisted steering later, you simply drill the FSJ box for fittings and use the internal valving for the ram... Nothing to it.
Hello
I found out this box http://www.ebay.com/itm/200828712735...52f71f&vxp=mtr does it fit to my cj7 1985 ? pitman and steering shaft ? Is it variable rate ?
It's pretty cheap with change !!! but i would like to be sure before ordered
Thanks
steff is offline
post #45 of 48 Old 11-11-2012, 09:42 AM
JeepnTXJ
What am I missing? The input shaft size and splines for a 83 CJ7 are .72" and 26 splines, which is exactly the same as an '83 J20. That is, however, according to autozone's website. Why would I need the coupler?
'83 CJ7. 258, T5, D300. D30, M20 1 pc. shafts
4" Skyjacker, 33x12.5.15 Nokian Vatiiva on wagon wheels.
JeepnTXJ is offline
CJ7 Steering Upgrade kdgraben Jeep CJ Forum 4 04-26-2010 11:51 AM
CJ7 Steering box upgrade CJ7RHD Jeep CJ Forum 6 06-25-2009 06:44 PM
Need a steering box upgrade CJ Chet Jeep CJ Forum 1 12-23-2008 09:27 AM
73 cj5 steering upgrade fl-jeep Jeep CJ Forum 4 09-20-2007 09:49 PM
Steering upgrade for '85 CJ7? medunwoody Jeep CJ Forum 3 07-02-2006 04:28 PM
