J20 Steering Box Upgrade - JeepForum.com
post #1 of 48 Old 05-26-2010, 08:15 AM Thread Starter
Jason790812
1981 CJ7
Anyone did the J20 steering box upgrade on a CJ with power steering? I've read about it on some other forums. Is it worth the hassle of trying to get the right box, or is it better to just buy a PSC or AGR? I know the J20 is ALOT cheaper and if it works as well as a PSC or AGR why spend the extra cash.
Jason790812 is offline
post #2 of 48 Old 05-26-2010, 08:41 AM
78treehugger
1980 CJ7
I did it and love it. Buy a manual steering coupler and bolt it on.
1980 CJ 7--3" Black Diamond, 1" body, locked both ends, 4.56, 35x12.50x15 SS LTB, "family" cage
It's easier to get forgiveness than permision.
Salad is what food eats!!!
78treehugger is offline
post #3 of 48 Old 05-26-2010, 09:43 AM
JeepHammer
Running On Empty...
1973 CJ5
Done 4 or 5 and they work GREAT.
If you want to go to hydraulic steering ram later, you just tap the box for lines and if you aren't running some 2.5" bulldozer ram it works fine.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #4 of 48 Old 05-26-2010, 09:56 AM Thread Starter
Jason790812
1981 CJ7
Do you have a part number? This should improve the stock ratio correct, because the J20 box is variable, so I won't feel like I'm driving a log truck? Plus a bigger piston to move bigger rubber around easier?
post #5 of 48 Old 05-26-2010, 11:10 AM
78treehugger
1980 CJ7
You can also modify your pump for more volume. I can turn my 35" SS LTBs with one finger on the street or trail. Obvioulsy going through obstacles I use my hand but every other time it's like driving my Dodge down the street. I just saw your response after replied to your PM. But yes it's a varible ratio. I believe it's a 17-13:1 same as the TJs.
post #6 of 48 Old 05-26-2010, 11:52 AM
lockedcj7
I just did this but it will be a while before it drives. I went to O'Reilly and told them I had an '85 J20. They ordered the steering gear and took my old one for a core. It bolted onto a HD mount like it was made for it. If you stick with the same year, you should be able to use stock hoses. I'm doing a motor swap so I'll be making up custom hoses anyway. I reasoned that '85 would be the most likely to have an improved box if any refinements were made along the way.
lockedcj7 is offline
post #7 of 48 Old 05-26-2010, 02:30 PM
bleoh
The J20 box has a larger internals then other FSJ boxes. But be careful at the national parts houses as they will often give you a regular FSJ box. The cap at the opposite end of where the steering shaft connects is larger on the J20 but I forget the measurement.
bleoh is offline
post #8 of 48 Old 05-26-2010, 03:07 PM
tcl632
1983 CJ5
So are y'all saying there is a cheaper steering box I have no power steering?
tcl632 is offline
post #9 of 48 Old 05-26-2010, 05:00 PM
JeepHammer
Running On Empty...
1973 CJ5
Late '70s early '80s FSJ or J-truck steering boxes,
Variable rate, where CJ had single rate,
They are heavier duty than the CJ boxes,
And they bolt right in to common power steering box brackets...
You will have to find/fabricate the power steering pump brackets for your engine,
Other than that, all you need is hoses...
Some people will need a conversion coupler or to change pitman arms for the right size, but that's cheap compared to the $800 and up for the 'Premium' boxes everyone wants to run,
And if you want to add ram assisted steering later, you simply drill the FSJ box for fittings and use the internal valving for the ram... Nothing to it.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #10 of 48 Old 05-26-2010, 05:40 PM
tcl632
1983 CJ5
that sounds like a good up grade I am going to replace all the moveing parts on my 5 what would I need to tell the local parts house?
tcl632 is offline
post #11 of 48 Old 05-26-2010, 05:40 PM
tcl632
1983 CJ5
replaceing all the steering parts
tcl632 is offline
post #12 of 48 Old 05-27-2010, 05:43 AM
JeepHammer
Running On Empty...
1973 CJ5
I buy the entire J-20 trucks for $100 to $300 dollars around here,
But if you were going to the parts store, pick a year and stick with it.
Like the guy in a previous post, LockedCJ7 said he asked for an '85 J-20 truck box,
If you do that, you should stick with '85 Power Steering pump, hoses, so all of that stuff fits without custom hoses.
The FSJ box is vairable rate, but it's not quite as heavy as the J-20 (3/4 Ton Truck) boxes.
I buy every J-20 truck I can find...
They are a gold mine for parts!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #13 of 48 Old 05-27-2010, 07:11 AM
bleoh
Here is a picture of the difference I was talking about. The cap on the J20 is about 3.5" wide, the CJ's and other FSJ are only about 3". Most of the time the chain stores will give you the smaller one.
http://members.cox.net/pmountsoa/J20Box/01sidexside.JPG
bleoh is offline
post #14 of 48 Old 05-27-2010, 08:01 AM
I6CJ7
I'm going to pick up one of these today to put on my 84 CJ7. What is the part number or actual name for the manual steering coupler you guys are talking about? And should I try and find a "new" box or just get a remanufactured unit, even though i'm not a huge fan of reman crap. I think a new box is like $300 vs. $135 for the reman.
I6CJ7 is offline
post #15 of 48 Old 05-27-2010, 08:02 AM
CSP
It's called a bell coupler and chances are you won't find one in a local auto parts store.
CSP is offline
CJ7 Steering Upgrade kdgraben Jeep CJ Forum 4 04-26-2010 10:51 AM
CJ7 Steering box upgrade CJ7RHD Jeep CJ Forum 6 06-25-2009 05:44 PM
Need a steering box upgrade CJ Chet Jeep CJ Forum 1 12-23-2008 08:27 AM
73 cj5 steering upgrade fl-jeep Jeep CJ Forum 4 09-20-2007 08:49 PM
Steering upgrade for '85 CJ7? medunwoody Jeep CJ Forum 3 07-02-2006 03:28 PM
