It's me again... - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > It's me again...
TERAFLEX JKU 2.5" Elite LCG Long FlexArm Lift Kit w/ March Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATEFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRI
Unread 01-06-2014, 10:01 AM   #31
John Strenk
John Strenk's Avatar
1976 CJ5
Just a note, use two wrenches to tighten the nuts up on the starter solenoid.
If you don't you could twist the contact inside making it an uneven contact. The contactor inside the solenoid will cock and jam and keep the starter engaged after starting.
Have you checked that you are getting full voltage to the starter? Bad cables can cause insufficient voltage from reaching the starter to keep it from pulling in all the way.
I put some new cables on and had starting problems and found that I was able to pull the cable right out of the terminals because of poor crimping.
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 01-06-2014, 12:36 PM   #32
goochieman83
2014 JK Wrangler
New issue, starter is not engaging the flywheel at all now. Can hear it just spinning but nothing else, makes a loud whinning sound. At least the grinding noise is gone.
Didn't check the voltage, no voltmeter. But the cables should be all good, as they were all replaced when I did the team rush upgrade.
goochieman83 is offline   Reply With Quote Quick reply to this message
