Is the Internally Splined Hub Conversion Still Available? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Is the Internally Splined Hub Conversion Still Available?
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectJKS Now Available at www.baseline4x4.com, Trackbars, SkidsFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 06-12-2014, 10:26 PM   #1
Agar426
1974 CJ6
By any chance is the old Warn internally splined hub conversion still available? I realize Warm sold that portion of their business, but I could swear I saw a mock up at the EJS vendor show in the Yukon Gear/Randy's R&P booth, but I'm not sure. Their web site isn't clear...
Agar426 is offline   Reply With Quote
Unread 06-30-2014, 12:24 PM   #2
Agar426
1974 CJ6
Ok....I think I found the part number from Yuukon Gear (YA W61650), but it costs almost twice as much as it did when Warn sold it, and Warn could never be mistaken for being a discount vendor. If this is the right part number, I have some questions:
1. On the old Warn setup, I believe you had to buy new axle shafts to go with this, as it was set up around the bigger u-joint. Or....am I confusing two un-related upgrades?
2. I haven't been able to get a response from Yukon, but I want to know if this kit is just the hub conversion, and if it includes everything required?
Thanks!
Unread 06-30-2014, 12:53 PM   #3
CSP
You're confusing two different things with the larger outer ujointed axleshaft. The Warn setup worked with the stock axleshafts.
Have you called Randy's Ring and Pinion? They are Yukon essentially.
CSP is offline   Reply With Quote
Unread 07-01-2014, 09:30 AM   #4
wm69
http://www.ebay.com/itm/YA-W61650-Fr...1e0e98&vxp=mtr
Still available, but pricey.
wm69 is offline   Reply With Quote
Unread 07-01-2014, 12:25 PM   #5
Agar426
1974 CJ6
Originally Posted by wm69 View Post
No kidding! They used to be $299 in the catalogs, and could be had for $250 if you searched. I'll call Randy's R&P, as that part number shows up at a few vendors, but not in the Yukon catalog.
Thanks everyone!
