Internal conversion kit lockout hubs - JeepForum.com
post #1 of 25 Old 06-16-2013, 09:37 PM Thread Starter
jurgen24
Just came back from a little 'light' wheeling and noticed that one of my lockout hubs disappeared with 3 of the bolts sheared off. It had the usual problem of bolts working loose.
I wanted to upgrade to Warn's internal hub conversion kit 37132, but its not made anymore. What are my best alternate options?
jurgen24 is offline
post #2 of 25 Old 06-16-2013, 10:07 PM
CJ_heath
CJ_heath is offline
post #3 of 25 Old 06-17-2013, 12:01 AM
LumpyGrits
Loc-tite.
Also look at Mile-Marker hubs. Best made, PERIOD!
LG
LumpyGrits is offline
post #4 of 25 Old 06-17-2013, 01:51 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I have some M-M hubs, but am disappointed in how the chrome is peeling off already, 2 or 3 years old...
Rick
Cutlass327 is offline
post #5 of 25 Old 06-17-2013, 06:17 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
One of the easiest fixes is to go to studs. Lock tight them in and install the hubs.
Here is an example, but you can assemble your own kit.
http://www.oreillyauto.com/site/c/de...PartType=C0142
jeepdaddy2000 is offline
post #6 of 25 Old 06-17-2013, 12:06 PM Thread Starter
jurgen24
Originally Posted by CJ_heath View Post
Thanks! I think this might be the best permanent solution.
Locktite and studs wont help now, the holes have been opened up so it will never stay in there tight. I can push the bolt in about 3/4" before it hits the threads.
jurgen24 is offline
post #7 of 25 Old 06-17-2013, 12:16 PM
LumpyGrits
Heli-coil inserts
http://www.helicoil.in/
LG
post #8 of 25 Old 06-17-2013, 12:30 PM Thread Starter
jurgen24
Originally Posted by LumpyGrits View Post
Heli-coil inserts
LG
Thanks! I'm gonna try those for now and then upgrade to the six bolt hub.
jurgen24 is offline
post #9 of 25 Old 06-17-2013, 01:03 PM
wm69
http://www.ebay.com/itm/110810950047...9#ht_449wt_904
wm69 is offline
post #10 of 25 Old 06-17-2013, 04:05 PM Thread Starter
jurgen24
OK decision time
6 bolt conversion kit : $240
W37132 : $500
I head good things about the 6 bolt, so I'm leaning that way, any one think that's a bad idea?
jurgen24 is offline
post #11 of 25 Old 06-17-2013, 04:34 PM Thread Starter
jurgen24
This looks the same as YA W37132
Says its for a Scout, 5 X 5.5", does anyone know 100% that it would fit? I called Randy's and they said its for 27 spline outer and should also work for CJ-7.
jurgen24 is offline
post #12 of 25 Old 06-18-2013, 07:51 AM
wm69
I saw it posted over on the Scrambler board by one of the old school guys, so I'm guessing it will work. I'd call Warn and ask them.
wm69 is offline
post #13 of 25 Old 06-18-2013, 07:55 AM
CSP
Scout outers are the same as CJ Dana 30. That kit will work.
CSP is offline
post #14 of 25 Old 11-01-2013, 08:24 PM
shooters_7
It'll work but, you need to replace the spindle so that the D44 outer axles will actually fit and with that being said you need the outer axle shaft or your 4wd won't work as the D30 outer axle is too small.
shooters_7 is offline
post #15 of 25 Old 11-01-2013, 08:40 PM
CSP
No, that's not correct.
That internal hub kit is listed for the Scout D44 and Scout D44 outers have the same diameter and spline count as CJ Dana 30 outers. They aren't the same outer axleshafts that the Chevy/Jeep/Ford/Dodge/etc D44s have.
CSP is offline
