Intermittent Spark on Cyl 1 and 6 - JeepForum.com
post #1 of 1 Old 03-17-2012, 09:55 AM Thread Starter
cj7inflorida
I am stuck. Read as many forum post as I could before I started going blind.
I have an 86, CJ-7, 258, fully nuttered, Weber 32/36 carb, Generic HEI dizzy.
Was running fine, went playing at Big Cypress, then started running extremely poorly (power loss, back firing, etc)
On cyl 1 and 6, using an inline spark detector, I am getting intermittent spark. Rest of the cyls look ok. Engine starts fine. Engine idles with obvious miss. Can drive but lots of hesitation and back firing.
I have replaced cap & rotor (Accel 8129), ignition module (BWD CBE4z), plugs (Autolite 985), rotated wires (MSD Street Fire - all ohms < 9), and nothing changes (now I have two sets of everything )....
I have also hooked directly from battery to dizzy and no change....
Timing is at 10
I can disconnect the # 1 while engine is running, and really can't hear a change (same with # 6).... others are noticeable.... I am amazed at this engine!
As it is spark related, I cannot see that it can be anything else but ignition...
Any thoughts?
cj7inflorida is offline
258 , cj , hei , miss , spark
No spark from distributor to spark plugs poolshark909 Jeep CJ Forum 14 08-06-2013 04:36 PM
HEI, Weak spark at coil, no spark at plugs Deadman 94 xj Jeep CJ Forum 13 07-30-2011 08:49 AM
Intermittent wipers Hillbillyd Jeep CJ Forum 3 04-24-2010 07:30 AM
No Spark to the spark plugs Dandude80cj7 Jeep CJ Forum 6 09-11-2005 09:02 PM
Intermittent wipers?? slickwillie Jeep CJ Forum 4 01-03-2005 09:11 AM
