Intermittent soft pedal - JeepForum.com
post #1 of 13 Old 01-28-2014, 11:55 AM Thread Starter
row684
My brake pedal randomly goes soft on the first press, firm the second. It has done this the last couple of days and last night my brake light (in the speedo) came on when it was soft. I've checked for leaks and found none. Brake fluid looks awful but is only about 2 years old when I did new lines calipers rotors and pads. Front reservoir was a little low too but hardly enough to bother adding more.
It's all stock manual brakes on an 84.
Master cylinder??? If so can I get a power booster and power master cylinder and will they bolt up to an originally manual Jeep?
row684 is offline
post #2 of 13 Old 01-28-2014, 02:29 PM
LumpyGrits
Bleed the breaks-Sounds like air in the line.
Did you just do some brake work maybe......
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 13 Old 01-28-2014, 03:13 PM
jcalhoon84
1980 CJ5
Sounds like a leak, possibly the master cylinder against the firewall...that's what caused that issue on mine.
jcalhoon84 is offline
post #4 of 13 Old 01-28-2014, 10:48 PM Thread Starter
row684
Originally Posted by LumpyGrits
Bleed the breaks-Sounds like air in the line. Did you just do some brake work maybe...... LG
It's been 2 years since I've had to do the brakes and they have worked fine until now, 2-3000 miles.
I will search for leaks more thoroughly tomorrow but the one reservoir is only down 1/4" over 2 years. the fluid does have a metallic look to it and is very contaminated however (symptom of something?) in the reservoirs would just like to isolate the problem before I flush it all...
row684 is offline
post #5 of 13 Old 01-28-2014, 10:53 PM
LumpyGrits
As the brakes wear-The reservoir goes down.
Flush and refill with FRESH/NEW, DOT 3 fluid. Never mix brake fluid types.
See if that changes anything.
LG
post #6 of 13 Old 01-29-2014, 02:13 AM
RWise
1981 CJ5
You might want to look at the rear (drum) brakes, if the auto adjusters stopped funtioning the pedal would slowly go down to the point it needs to be pumped to get enuf fluid to the rear slaves to move the shoes far enuf to hit the drum.
Brake fluid is the most over looked fluid on any vehicle, it seems we expect it to last forever in its sealed system, even though moisture (condesate) can go through metal and contaminate the fluid. Not to mention the particals of metal and ruber floating(or suspended) around in it,,,, which is kinda like grinding compound.
RWise is offline
post #7 of 13 Old 01-29-2014, 10:04 AM Thread Starter
row684
Originally Posted by RWise
You might want to look at the rear (drum) brakes, if the auto adjusters stopped funtioning the pedal would slowly go down to the point it needs to be pumped to get enuf fluid to the rear slaves to move the shoes far enuf to hit the drum. Brake fluid is the most over looked fluid on any vehicle, it seems we expect it to last forever in its sealed system, even though moisture (condesate) can go through metal and contaminate the fluid. Not to mention the particals of metal and ruber floating(or suspended) around in it,,,, which is kinda like grinding compound.
The parking brake still works correctly, would this rule out the adjusters?
Any idea where the metal flakes and other crap floating around in it could have come from? The fluid was clean this last summer.
row684 is offline
post #8 of 13 Old 01-29-2014, 10:09 AM Thread Starter
row684
As the brakes wear-The reservoir goes down. Flush and refill with FRESH/NEW, DOT 3 fluid. Never mix brake fluid types. See if that changes anything. LG
I will work on that today.
row684 is offline
post #9 of 13 Old 01-29-2014, 01:03 PM
RWise
1981 CJ5
No but you may be able to set the parking brake and have more pedal.
Normal wear! The ruber parts rubing against metal parts, also crap that was already in the system. When I worked with hydrolics, the formula they used to predict the next down was 50% of the previous run time, no mater how clean the job was done.
RWise is offline
post #10 of 13 Old 01-29-2014, 08:07 PM
jeepmor
jeepmor's Avatar
Second on checking rear drum adjusters. Sounds like they are not spinning anymore and your brakes have worn, making the wheel cylinders have to move farther to get the brakes to bite. Does not sound like air in lines, although, this is the same symptom typically. Engage E-brake and see if it becomes consistent. If it does, that's it. If not, could be air in there somehow, but doesn't sound likely from your description.
jeepmor is offline
post #11 of 13 Old 01-30-2014, 03:34 AM
RWise
1981 CJ5
The adjusters activate when braking in reverse, IF the pedal comes up with the parking brake set, you might try driving in reverse and pumping the brakes, fairly hard stops may jar them loose and let them adust out.
RWise is offline
post #12 of 13 Old 01-30-2014, 02:49 PM
jeepmor
jeepmor's Avatar
I used to do this in my culdesac, always wondered if the neighbors thought I was crazy.
jeepmor is offline
post #13 of 13 Old 01-31-2014, 10:07 AM
Balvar24
1979 CJ7
I recently had the cable for the adjusters break in my rear brakes. Check that too.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
