Intake Manifold Gasket change 258 - JeepForum.com
post #1 of 3 Old 10-20-2002, 06:46 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
I think my intake manifold gasket is leaking a little and would like to change it. Does anyone out there have experience with this project on an 85CJ with a stock 258ci engine?
1. are the intake and exhaust gaskets two separate gaskets?
2. can the intake be changed without changing the exhaust gasket?
3. do some people use no gasket, just PVC?
The reason I think my gasket is leaking is after being on the freeway for a few miles and coming to an exit, the idle becomes very rough. The RPM don't seem to decrease - if anything it increases slightly but is rough. After a couple of miles of driving the surface streets it smoothes out at idle. So, I think when it is running at the higher RPM for extended periods the intake manifold must develop a leak probably somewhere near the exhaust manifold where it gets the most heat. After cooling a bit by driving at the slower speeds, it goes away.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #2 of 3 Old 10-21-2002, 10:08 AM
KG4PAM
it may not be your intake gasket. '85 would have a computer (unless you removed it...) possibly it could cause a problem? i dont know anything about vehicle computers, but it might be something to check into.
now, for your question...
'81 and up 258's should have separate intake and exhaust manifolds/gaskets. mine is an '81, and it does.
yes, you should be able to change the intake without removing the exhaust. the exhaust is bolted to the block with (4?) bolts/nuts, and the intake seats between the ports of the exhaust, using bolts with washers that seat on a metal lip cast into the intake. there should be (8?) of these. as a side note, when you replace the gasket, you probably would want to replace these with new, grade 8 bolts(+antiseize compound). forgive me if this description does not make sense, when you look at it, you will see what i mean. to get some of the bolts out, you will have to use some u-joint ratchet extensions, this is fun...
PVC? i am supposing you mean RTV, this would not be good (or necessary) to use on the intake . when you start the engine after charging the gasket, it will smoke a little, this is the gasket heating up and sealing itself.
if you buy the gasket at a place like autozone, it will probably come with both intake and exhaust gaskets, + a little o-ring and gasket for the manifold heater. if you into the motor that far, you might as well change both while your at it.
i hope that i have been a help, good luck!
jairus
'81 CJ-7 Got it when I was 16!
'06 Hummer H3, boulder gray, Adventure Package(electric rear locker and 70:1 crawl ratio BONE STOCK)
'71 Kaiser-Jeep M35A2 Deuce and a Half cargo truck, with winch. <for sale>
KG4PAM is offline
post #3 of 3 Old 10-23-2002, 01:34 AM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Well, I found the problem. I drove it several times at high speeds and when I'd come to a stop I'd adjust the air mixture screws. Sometimes it would help a little and sometimes it got worse. Finally, today I was doing it again and when I came to a stop, I could hear a high pitch whistle noise coming from under the hood. I raised the hood and sprayed brake cleaner at the intake manifold and carb base plates. Well, low and behold, the idle changed drastically when spray touched the rear two pieces of the intake manifold. The idle smoothed out and the whistle noise went away. I will change the gaskets tomorrow.
PS - I did bypass the computer since I run a Weber carb and have no need for a computer to control mixture settings.
Intake manifold gasket ? jp360cj Jeep CJ Forum 6 06-12-2009 11:26 PM
Intake Manifold Gasket - Where to Get? JarWithLid Jeep CJ Forum 14 02-11-2009 09:44 AM
Intake manifold, carburator gasket Bill Hall Jeep CJ Forum 3 03-10-2008 06:33 AM
AMC 360 Intake Manifold Gasket rhinolinedcj5 Jeep CJ Forum 2 09-15-2006 08:51 AM
Intake manifold gasket is done Jeep Daddy Jeep CJ Forum 0 10-24-2002 11:15 PM
