Intake Bolts - JeepForum.com
post #1 of 5 Old 04-02-2009, 06:07 PM Thread Starter
wifflesniffle
Intake Bolts
What type of bolts such be used to replace the intake/exhaust bolts? Also should the factory washers/spacers be reused or replaced. If replaced, what did you guys use?
Matt
'85 CJ7, 258, T-5, Dana 300 T/C, 4" BDS lift, 4.10's, Dana 30 w/ Detroit Truetrac, AMC 20 open w/ 1pc Moser axles, Borla header, JB Fab twinstick, Smittybilt XRC8, Maxbilt console.....
wifflesniffle is offline
post #2 of 5 Old 04-03-2009, 10:44 AM
Stan99
1978 CJ7
Bump. I am having the same problem finding the washers that clamp both the exhaust and intake manifolds to the head.
1978 Jeep Cj7 Soa, Shackle Reversle, 36x13.5x15 Irocks, 4.5 Stroker MPI, Dana 300 twin Sticked, 4.88's
Stan99 is offline
post #3 of 5 Old 04-03-2009, 11:00 AM
Bear-Olemiss
1981 CJ5
You must special order them from a parts house. Had to get mine from napa
BAIL! "Welder's have hotter rods"
Arc-Up Welding Inc.
Vicksburg, Ms
Bear-Olemiss is offline
post #4 of 5 Old 04-03-2009, 11:56 AM
keith460
Jeep. There's Only One
keith460's Avatar
You can also purchase the heavy washer from McMaster-Carr in stainless steel to replace the cup type from the factory. They are generally called fixturing washers and are 1" O.D. x 13/32" I.D. x 3/16" thick for 3/8 bolts. McMaster-Carr P/N is 98125A031.
These are an excellent replacement washer as they are large diameter and in "thick" stainless for about $8.00 for a 10 pack. I use them on my 258 engine.
1984 CJ-7 Renegade
keith460 is offline
post #5 of 5 Old 04-03-2009, 01:55 PM
chill254
1984 CJ8
What is the size, length, and thread pitch of the manifold bolts? Also how many would you need to replace all of them? I am planning to replace mine along with a new intake.
chill254 is offline
Replacement intake/exhaust bolts/studs? attworth Jeep CJ Forum 3 06-29-2009 07:18 PM
header intake bolts stlouis400ex Jeep CJ Forum 4 04-01-2008 07:09 AM
intake manifold bolts petey156 Jeep CJ Forum 1 05-20-2006 12:15 AM
heated intake manifold to cooled intake manifold? chris97e Jeep CJ Forum 2 11-23-2004 05:15 PM
broken rear spring hanger bolts cj5. got the broken bolts out now what? COBRA5LADDICT Jeep CJ Forum 6 11-12-2004 06:55 PM
