#1 | |
instrument cluster
Can someone tell me what is the best way to remove the instruments in the dash. I have an 85 cj with factory clock and tach and need to do some repair work on both. Thanks
#2 |
Alpha dog
My opinion is to lower the windshield (carefully, the hinges maybe frozen with rust), remove the dash pad, remove the steering column bezel, and remove allof the dash screws. The dash will then be able to move a few inches, and this should give you the room needed to get behind everything.
I'm sure there are folks on this forum who can remove those items with the dash in place, but I'm not one of them, it's just too tight back there for me.
'82 Scrambler - NV4500/4.5" lift/33" BFG/Holley 390 - twin stick, and my windshield washers work! Full 1/2 cab Cage 2004 Grand Limited 4.7 HO - OH Boy! 2010 Grand Laredo 5.7 Hemi - SICK - work vehicle -gone - replaced by an 08 Tahoe - nice ride. "Both my Doberman and my Jeep can accurately be described as 'black and rust.'" "I got a fever . . . and the only prescription is more cowbell" |
#3 |
Personally I just remove the entire dash. It makes life alot easier in the end!
#4 |
Parts Locator
If it is just the clock and tach that you need to remove you can reach up behind them and unscrew the 'U' bracket that holds each one in. The gauge will then slide out the front of the dash and you can unplug the wires to them. Putting them back in will probably be more difficult then removing them, unless you remove the entire dash, but it can be done.
84 CJ7 Northstar V8 Pictures of it, http://s56.photobucket.com/albums/g198/cjinpa/odds%20n%20ends/?start=all 91 YJ Renegade, Daily Driver since 1991. 97 TJ daily driver. 2011 F250 King Ranch. Jeeps that I am currently parting out; 91 YJ Renegade 5spd 1990 YJ auto 1991 YJ 4cyl 5 spd Just my luck I was born in the land of plenty now there ain't enough. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
