Installing Power Steering on a 74 CJ5 - JeepForum.com
post #1 of 4 Old 05-22-2010, 09:28 PM Thread Starter
gbear
1974 CJ5
I would like some information: The steering gear has a larger input shaft. Will a lower coupler kit for a 76 power steering model fit the 74 manual steering shaft?
And will the low and high pressure hoses for a 76 work on the retro of a 74? I got the gear from " Quadratec" and it was a direct bolt up. The power steering pump and bracket came from a V-8 Wagoneer not sure of the year but it fit perfectly to the 304 V-8 in my CJ. Any help would be appreciated on the steering shaft and hoses.
Thanks
Jim
1974 CJ-5 w/304 V-8, PTO winch
1995 F-250 7.3 Powerstroke Diesel; 1967 Mustang 289 V-8;1954 F-100 Project truck; 1927 T Model Project truck
gbear is offline
post #2 of 4 Old 05-25-2010, 09:14 AM
CSP
Yes the larger coupler will fit the '74 steering shaft.
Any '79 and older hoses will work as long as the fittings on the pump and box are both for inverted flare. Saginaw boxes and pumps went to o-ring fittings in 1980, so it would have helped for you to know the year of your pump donor.
CSP is offline
post #3 of 4 Old 06-09-2010, 06:59 PM Thread Starter
gbear
1974 CJ5
Thanks, I got it all figured out and it's great. I should have done this years ago.
Jim
gbear is offline
post #4 of 4 Old 06-09-2010, 07:03 PM Thread Starter
gbear
1974 CJ5
All I had to do was find a 79 or older pump and get the rear fitting, and put it in my pump. That is all you have to do to make a newer pump work with older hoses. It is getting harder and harder to find mid 70's vehicles in the wrecking yards.
Jim
gbear is offline
Power Steering and Power Brake upgrade? Chris Jeep CJ Forum 37 12-24-2014 11:02 AM
New steering box and power steering pump=very tight steering? SuB8HaVeN Jeep CJ Forum 15 04-12-2010 10:13 AM
installing painless kit-power going to coil but not to distibuter Matt_G Jeep CJ Forum 7 09-19-2009 10:32 PM
Steering box leaking, losing power steering fluid hidehunter Jeep CJ Forum 17 11-24-2008 08:01 PM
Will the hoses on a 82 power steering pump mate up with a 89 power steering box? Mud Machine Jeep CJ Forum 2 12-17-2005 08:18 AM
