installing one piece axles in amc 20 - JeepForum.com
post #1 of 5 Old 06-19-2003, 06:54 AM Thread Starter
c_herrman
Hi guys,
I"m installing heavy duty one piece axles by Yukon Gearing in my cj....the first problem is that there were no intstructions, or diagrams as to the order of pressing....my second question has to do with how the new axles are held in to place? any help, suggestions, diagrams etc. would be greatly appreciated....i want to get these in right
Cory
c_herrman is offline
post #2 of 5 Old 06-21-2003, 11:19 AM
dana60cj
dana60cj's Avatar
There should be some kind of bearing retainer, a bearing/race, and some sort of shim to fit in the housing and a seal.
The first to go on the shaft, on the bottom when the splines are in the air and the flange is on the ground, is the bearing retainer, then the brake backing plate, then the bearing, then the race, then the shim, or shims. The shim will probably be a round block. The seal is pressed to the back of the housing,CAREFULLY. Then the whole thing goes in, the four bolts on the bearing retainer bolt to the axle end. Lube the seals with some oil to prevent burning them up before oil can reach them.
Hope it helps I've taken a few apart to fix them, and install them. Any more q's write Me. Good luck.
'84 CJ-7, 6" lift, 33" BFG's, I6, .030 Over, Comp Cam, 400cfm Weber, K&N, T-18, 4 Core, Snorkel, D60 Detroit, Custom CV Driveshaft, 1350 U-Joints, D30 True Trac, Alloy shafts, S.R.S. w/ buggy springs, Custom Folding Shackles and Spring Hinges, Custum Tire Rack, Designed On Board Air, Optima's. Sneaky Jeep Owner #3.
dana60cj is offline
post #3 of 5 Old 06-21-2003, 12:23 PM
80cj
80cj's Avatar
1980 CJ5
I would call Yukon Gear or whoever you made the purchase from and ask for the instructions. That way there will be no misinterpretation of some one else's directions. Correct installation of your axle kit can affect the safety of your vehicle as well as eliminate the possibility of messing something up.
80cj is offline
post #4 of 5 Old 06-21-2003, 12:54 PM
knowlwk@snowhill.com
1980 CJ7
I second calling the manufacturer. Get it right the first time.
Some donut hole that had my CJ before I got it didn't install a set of Moser's correctly.. I pulled them to fix a leaky seal and the bearings (what was left of them) fell apart in my hands. Whoever installed them left the spacer out and the bearing came apart in the tube, chewing up the brake backing plate and end of the axle tube. The bearing rollers looked like pistol slugs shot through a 2x4.
I ordered a new set of bearing and seals, and follwed the instructions... about 4500 miles now, without problems.
'80 CJ7, 258 W/Autojuicer, MC 2100, TFI, SummitRacing CDI, MORE SRS, Moser 1-pc, YJ tub on 1" body lift, YJ family cage.
knowlwk@snowhill.com is offline
post #5 of 5 Old 06-21-2003, 10:25 PM
magicmudder
magicmudder's Avatar
Check their website. I think I remember seeing instructions on their. They also have a great gear installation write-up. I would link directly, but I don't have adobe acrobat on this computer so I can't get to that page but their website is http://www.yukongear.com
84 CJ7, 258, shackle reversal, 4.56 gears, lockrite , moser one piece axles, 37" SSR's
magicmudder is offline
Is there a write up on installing 1 piece axles? XJ99 Jeep CJ Forum 12 01-27-2007 04:39 PM
One piece axles ronprice Jeep CJ Forum 10 11-25-2006 06:25 PM
2 piece axles 77cj7 Jeep CJ Forum 1 02-08-2006 11:22 AM
CJ7 one piece axles cj7taz Jeep CJ Forum 7 09-25-2003 05:51 AM
one piece axles HELP! mixjforlife Jeep CJ Forum 2 09-12-2003 12:23 PM
