Installing one Piece axles - JeepForum.com
post #1 of 7 Old 07-20-2010, 07:56 PM Thread Starter
Cajunn
I was able to pull the thrust block out, without removing the differential. I installed the passenger side axle. My question is how tight should it be when you turn it by hand? i can turn it with one hand with some tension, but definitely not free spinning, is this correct?
Cajunn is offline
post #2 of 7 Old 07-21-2010, 08:41 AM Thread Starter
Cajunn
Shims
After reading thru the forum again, it seems I have to much of the bearring protruding out, about 1/8", which is (.12). Now original when I removed the original axles (driver side) they was two shims. Could I use one on each a side to be within tolerance, instead of removing the spacer, tearing up the inner seal, and grinding the spacer down?
Cajunn is offline
post #3 of 7 Old 07-21-2010, 11:13 AM
jeepwhore
You already have to tear it apart to correct it...might as well do it right. If the shims are the right thickness I suppose you could use them but I'd still rather do it according to the mfg. instructions.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #4 of 7 Old 07-22-2010, 05:09 PM
baja67
1980 CJ5
I just did mine and test fitted the bearing spacers before I put the seal in. Actually used the old axle dust cover as a tool to tap in the bearing housing. The first time I put it in, I marked both the spacer and the axle housing so I could put in back in the same each time I took measurements. Once I got it correct, then popped it back out with my slide hammer and installed the inner seal and then the spacer. That way you won't mess up anymore seals each time you take a measurement.
baja67 is offline
post #5 of 7 Old 07-22-2010, 08:45 PM Thread Starter
Cajunn
ok thanks, I will try that method.
Cajunn is offline
post #6 of 7 Old 07-24-2010, 04:28 PM
baja67
1980 CJ5
How is the install going? Did you get the measurements within spec?
baja67 is offline
post #7 of 7 Old 07-25-2010, 08:31 PM Thread Starter
Cajunn
Yes, took them out and to grind a little off. I put her back together today, so far everything looks good! Thanks for a the info!
Cajunn is offline
axle , bearings , end play , one piece , one-piece axles , preload , retainer , seal , shims , spacers
1 piece axles TJbino4 Jeep CJ Forum 18 09-16-2007 08:32 AM
Is there a write up on installing 1 piece axles? XJ99 Jeep CJ Forum 12 01-27-2007 04:39 PM
new one piece axles wilf Jeep CJ Forum 3 02-01-2005 08:42 AM
One piece Axles? Feenix Jeep CJ Forum 4 08-27-2004 11:15 PM
installing one piece axles in amc 20 c_herrman Jeep CJ Forum 4 06-21-2003 10:25 PM
