Installing model 20 outer wheel seal - JeepForum.com
post #1 of 3 Old 09-08-2011, 09:45 AM Thread Starter
pitman91
Ok, I am installing a new outer wheel seal and bearing and got it all put back together. Problem is my wheel is either loose(has play in the bearing) or too tight(wheel wont spin or gets really hot). I have the 2 piece axle still and I know that I need to go to one piece but just gonna get me by for a bit until I have the money. What is the order that it all goes back together( Backing plate, outer seal, outer seal retainer?) I read on here that you just tighten up the nut and its good. Oh, I am working on the right side and from what I read the left side is the side with the adjustment/shims. Did I put it back together wrong maybe? Just got me stumped.
'80 CJ7, 304, T-176, Dana 300, Dana 30 and Model 20 w/ 4.10's, 35 X 14.5 Boggers, 6" Lift--FOR SALE!!
'04 Wrangler Sport, 6 cyl., 4 speed auto, 4" lift, 33X12.50
pitman91 is offline
post #2 of 3 Old 09-08-2011, 10:09 AM
waterdowg
Look at post 10 from JeepHammer Does that help?
http://www.jeepforum.com/forum/f8/am...ement-1061234/
waterdowg is offline
post #3 of 3 Old 09-08-2011, 10:48 AM Thread Starter
pitman91
Cant believe I didnt find that searching. Ill see what I can do now, Thanks!!
pitman91 is offline
Which way to install Inner and Outer Seal on a AMC 20? Cajunn Jeep CJ Forum 3 07-15-2010 08:14 AM
how do you seal your model 20 sherlocktk Jeep CJ Forum 32 01-26-2010 08:44 AM
Inside of AMC 20 rear end, where the outer seal goes is damaged PLEASE HELP!! nathanm40a1 Jeep CJ Forum 2 08-27-2009 08:31 AM
4wd outer window door seal ? a2tripp Jeep CJ Forum 0 11-18-2008 09:04 PM
Model 30 front axle and model 20 rear pinion oil seal? Paul M Jeep CJ Forum 6 06-08-2003 07:33 AM
